Go to Post the golden rule of robotics for the 21st century: Do unto robots as you would have them do unto you - KenWittlief [more]
Unread 02-02-2012, 21:38
adampaskowitz adampaskowitz is offline
FRC #4345
adampaskowitz is an unknown quantity at this point
Building a gearbox / Attaching a motor?
OK, here's an embarrassingly basic question, embarrassingly late in the season - we have all these motors with round shafts sticking out of them, and realized that were not sure how to connect them to gearing, and then to wheels and other potentially spinnable things. Can anyone tell me how to build a gearbox and connect the motors to the gears, or, more likely, point me to a helpful resource that would give step-by-step directions? Are there ready-made parts available somewhere, since we have very limited machinery & tooling?
Unread 02-02-2012, 21:41
Andrew Lawrence
Posts: n/a
Re: Building a gearbox / Attaching a motor?
Build a gearbox? Why not use the CIMple Boxes included in the kit? Those gearboxes are awesome!
Unread 02-02-2012, 21:42
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
One site will help you with almost everything (or two sites)
Andymark.com has all kinds of gear boxes and other robotics things. They are a sponsor of FIRST.
Also the banebot motors you will have to use their gear boxes banebots.com (andymark only has a few that would work with these motors)
Because you are a rookie team i STRONGLY do not recommend attempting to make your own gear box. My team has been around for 11 years and we still dont make our own gear boxes.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 02-02-2012, 21:53
CarlosGJ CarlosGJ is offline
FRC #0418 (Purple Haze)
Team Role: Mechanical
CarlosGJ is an unknown quantity at this point
Before you can connect a motor to any kind of gearbox, you need a small gear (called a "pinion") on the end of the motor shaft. While CIMs, etc have a small keyway in the shaft, you have to press-fit to smaller motors. On my team, we first heat the pinion to about 300 degrees in a toaster oven (to expand it slightly), then (while it's still hot) press it onto the shaft with an arbor press. When the pinion cools and tightens on the shaft, it is a very strong connection. While I highly recommend the oven and press method, I have heard that it is possible (albeit difficult and risky) to press fit at room temperature with a hammer. Tip: the bearings and bushings in the motor case are nowhere near strong enough to support the loads involved in press fitting. The motor needs to be resting on the bit of shaft protruding from the bottom, so only the shaft is under stress. Other tip: whatever the method you use, the greatest risk is bending the shaft, resulting in a useless motor. Make sure everything is straight before you start. Also, continuous force is less likely to bend the shaft than impulse, thus the arbor press as opposed to hammer.
Unread 02-02-2012, 23:05
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Double post.
"Jack of all trades, master of none, though offtimes better than master of one".
Last edited by coreyjon : 02-02-2012 at 23:13. Reason: The internet at McMurdo Station, Antarctica is screwy.
Unread 02-02-2012, 23:12
coreyjon's Avatar
Flight Engineer
I've been doing this for a long time (2001) - I remember the drill motors, i've cut gears, and I've designed and built gear boxes from scratch. I can't make a better recommendation than akoscielski3. As a rookie team this late in the game, get yourself some of those CIMple boxes.
If in the future if you want to explore building/designing gearboxes the key is to decide very early on, and then have a back up plan especially the first time you try it just in case things go awry. Things to keep in mind are:
Motors: understanding power output, no load (free) speed, and what speed you can expect under load (my rule of thump 80-81% no load)
Gear Reductions required: Set a target speed (IE 12fps), decide on what size wheels /track set up your using. Then work from both ends IE expected loaded speed of motors on one side to the speed required to move your wheels/tracks to achieve the desired speed. At this point it's just a puzzle to solve the proper reductions.
There are many variables to consider: as you increase the number of reductions (intermediate shafts) you reduce efficiency. How much backlash should you use (.001" is my rule of thumb). don't forget about how you plan on connecting the gear box to the wheels (theres a chance for another reduction, so don't waste it).
Designing drivetrains/chassis (now teaching how to) is primarily where I focus myself. It's very rewarding, but also time consuming. With places like Andymark now offering ready made robust gear boxes it takes a lot of guess work and design work out of it leaving you and your team to spend more time on strategy and other end effectors to play the game.
Good luck to your team, no reason to be embarrassed by a question. This forum is here to be an idea sounding board, sanity check, and learning center.
Unread 02-02-2012, 23:21
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Don't worry about asking "embarrassing" questions. Even if you think something should be obvious, many people don't know it. It is also important to ask and find out the correct way of doing things to prevent destroying components. Nobody expects you to know everything about how to put together a robot if you have never done so before. (Also, for a rookie team, it isn't that late in the season. Some teams come to regionals without a working robot.)
Also, I knew about press-fitting, but I didn't know how to do it, so thank you to the poster and those who answered. I wish I had asked last year when we were trying to make a minibot.
