Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
Unread 02-02-2012, 23:02
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
What is a kitbot?
I heard someone use the term kitbot.
What does it mean?
Is it simply a drivetrain using basic KOP parts?
Unread 02-02-2012, 23:05
Andrew Lawrence
Posts: n/a
Re: What is a kitbot?
What does it mean?
The kitbot is a simple, well-engineered drive train created by the folks at Andymark that utilizes the parts in the kit. It's a popular drivetrain, and is often used by teams with some custom modifications, the most common being different wheels, speeds, etc.
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Short answer: yes.
But see this:
http://www.simbotics.org/resources/kitbot
Unread 02-02-2012, 23:07
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
What does it mean?
Yes. The Kitbot is the AndyMark C-Base chassis, a pair of CIM motors running through CIMple Boxes to 2-4 wheels via chain, and the control and power system to run them (cRIO, Jaguars, PDB, Digital Sidecar, main breaker, D-link router, and battery, all mounted on plywood.)
You can build it completely from the KOP and a piece of plywood.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-02-2012, 07:12
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
The "Kitbot" was the name for the IFI designed basic drive system that was first included in the 2005 KOP. This was a basic 4WD robust drive train with single speed gearboxes and was designed by JVN and Paul Copioli.
When the AndyMark C-Base started to be included in the KOP people started refering to that as the kitbot as well, though this is technically incorrect.
I'm trying but can't remember what year the switch happened.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 03-02-2012, 07:29
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
2008 was the last year that the IFI Kit bot was supplied in the KOP. I believe that in 2005 and 2006 it was supplied with the Copioli Single Speed and Skyway wheels, 2007 switched to Banebot Planetaries and AM wheels, and 2008 used Toughboxes and AM wheels.
2009 was the first year for the C-base and it's gone through 4 iterations since then. IIRC, 2009 was 2 Motor 4WD with Slick wheels, 2010 was 2 motor 4WD with 8" wheels and the lift kit, 2011 was 2 motor 6WD (though only two wheels were powered) with 6" wheels and CIMple boxes and 2012 is 2 motor 6WD with 6" High grip wheels.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
