Go to Post studies have shown that postive feedback works better. Driver should get a shock until he obtains target lock, then it stops. Performance incentive :^) - KenWittlief [more]
Unread 03-02-2012, 00:55
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Question [FTC]: Servos locking up when deploying FTC code to NXT
My FTC team is having a hard time programming our servos. We have programmed the system so that one button on the gamepad makes the servo go to one place, and another button makes it go to a different position. This setup works perfectly when running as a "prototype" program, but when we deploy it as actual "FTC" code, the servos will twitch when the button is pressed, then become non-responsive. Any help is appreciated, and since our competition is tomorrow, we are really in need of a solution.
Unread 03-02-2012, 04:57
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is online now
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Team Role: Coach
Rookie Year: 2007
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Re: [FTC]: Servos locking up when deploying FTC code to NXT
Could you post the code? There may be a variety of reasons that it's not working and we can only know for sure if we can see your code.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 04-02-2012, 23:09
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Rookie Year: 2011
Red face Re: [FTC]: Servos locking up when deploying FTC code to NXT
Sorry for the late response, but we fixed it. As it turned out, it was linked to a completely nonrelated issue: We got the schematic in the program wrong.
Unread 05-02-2012, 07:55
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
It doesn't sound like your problem, but for others, there is a patch tole which fixes another servo problem. There is a new feedallwatchdogs.vi that van fix botching servos. Saw the problem at Md qual yesterday.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 05-02-2012, 11:14
PhilBot's Avatar
AKA: Phil Malone
Here is the vi that needs to be loaded into:
C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\NXT\HiTechnic
It's FeedAllTETRIXWatchdogs.vi
https://decibel.ni.com/content/thread/11347
If you are using servos, and they don't respond correctly in auto or teleop... it's worth downloading.
Phil Malone
Unread 28-02-2012, 11:37
hokieteach hokieteach is offline
FTC #5465
hokieteach is an unknown quantity at this point
Hello,
Whippet we are having the exact same issue that you are describing. Can you give us some insight into what you did to resolve the issue.
Unread 09-03-2012, 00:01
PSHRobotics PSHRobotics is offline
FRC #1182
PSHRobotics is an unknown quantity at this point
Thanks so much for providing this link. We were at the Missouri state event and found this thread by random luck right before the national anthem started for the event and had rewritten our code several times thinking that we had a coding issue. We even switched motor controllers and were about to switch servos.
The problem is very weird in that it only affected out 5 and 6 servo ports on the servo controller while all other servos worked fine.
