Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 03-02-2012, 13:24
GorillaGearhead GorillaGearhead is offline
FRC #3587
GorillaGearhead is an unknown quantity at this point
Imagining cRio as not to deploy each time
Can anyone share with me a link to create a CRio image so that we do not need to deploy each time to test.
I hope that this is the right protocol
thanks
Unread 03-02-2012, 14:17
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Imagining cRio as not to deploy each time
Down at the bottom of the project explorer, There should be a yellow icon next to the words "RT Startup Project" (or something along those lines, it is at the very bottom of that list). Click the plus symbol next to this, and another selection will drop down. Right click on this new item, and select "Build" from that. Wait the ~2 minutes for that to complete. When it has, right click the icon again, and this time, choose "Run as Startup". This will permanently load the code onto the robot, even after it is shut off. This should be done every time, unless you need the code to be running for realtime debugging.
I'm right 90% of the time, so why worry about the other 3%?
Unread 05-02-2012, 16:34
FRC #3587
Rookie Team here.
can you post a screen shot of where that it?
Thanks a bunch
Unread 05-02-2012, 16:44
Cecil's Avatar
AKA: Alex Hummel
I can, please hold one moment.
Unread 05-02-2012, 16:54
Cecil's Avatar
AKA: Alex Hummel
Here you go: First, you must select Build, and then when that is done, select Run as startup.
