Go to Post I know that it's often dangerous to use common sense in a YMTC thread... - Kris Verdeyen [more]
Unread 03-02-2012, 13:38
kingkurry kingkurry is offline
FRC #4067
kingkurry is an unknown quantity at this point
Spike Relay code failing
We are using a spike relay to control a spinbrush in the front of the robot to sweep in balls. I created a new spike relay object and used the left trigger to get it to move. However, every time I hit the trigger, the ENTIRE robot jerks forward and then becomes unresponsive until I disable and renable teleop. And when i say jerk froward, I mean that the CIM motos, which are connected to our 4 jaguars, move and the spin brush moves too, albeit for a short period of time. Is there some issue in the code that could cause this to happen?
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Relay;
public class Test extends IterativeRobot {
    Joystick leftStick;
    Joystick rightStick;
    RobotDrive robot;
    Relay spike;
    double leftValue, rightValue;
    public void robotInit() {
        leftStick = new Joystick(1);
        rightStick = new Joystick(2);
        robot = new RobotDrive(1,2,3,4);
        spike = new Relay(5);
    public void disabledPeriodic(){
        //robot.setSafetyEnabled(false);
        robot.tankDrive(leftStick.getY(),rightStick.getY());
        //robot.tankDrive(leftValue, rightValue);
        //spike.set(Relay.Value.kForward);
        if(leftStick.getRawButton(1)){
Also, I am plugging in the relay to the relay port of the sidecar. We are just using 5 here because we tried switching between different relay port numbers.
