Go to Post You can never have enough figurative language. - Travis Hoffman [more]
Unread 04-02-2012, 01:19
Ddres0605's Avatar
Ddres0605 Ddres0605 is offline
FRC #2638
Ddres0605 is an unknown quantity at this point
Joystick - Action Only Once
Hey. I need some help with some joystick programming. I want to make it so an action happens only when the button is pressed down. Example: A button is pressed and a bimba extends or something like that then, it only retracts when the button is pressed again. Any help would be appreciated! Thanks!
Unread 04-02-2012, 08:16
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: Joystick - Action Only Once
What you are referring to is called latching a button. Once you press and release a button, it maintains that state until it is pressed again. In the LabView FRC examples, there is an example demonstrating this. You can get to it by starting at the LabView Getting Started Window. Select 'Support' on the left and select 'Find FRC Examples'. You will see folder call 'Joystick'. Under here is an example program demonstrating button latching.
Give it a try and if you have more questions, post back.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 04-02-2012, 11:47
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Team 358 shares some code examples on this link including various button examples. Hope that helps:
http://team358.org/files/programming...2009-/LabVIEW/
