Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 04-02-2012, 10:47
JacobGH JacobGH is offline
FRC #1849
JacobGH is an unknown quantity at this point
how to print debugging statements to Netbeans
We're using Netbeans with Java to run our robot. If I upload new code to the robot then, as part of the compile/upload/reboot process a Netbeans is terminal is connected to the cRio, so any System.out.println() statements get printed to the development machine. But so far, I don't know how to get that terminal connection without the whole code-upload process. How do I do that?
Unread 04-02-2012, 10:52
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: how to print debugging statements to Netbeans
Go to your Start menu and select NetConsole for cRIO on a machine connected to the robot network. The cRIO uses broadcast messages for the NetConsole so it should begin receiving the messages automatically. Note that you cannot use NetConsole and have the Netbeans console running at the same time on the same machine because they bind the same port. The can run at the same time on different machines and should both receive the messages.
Unread 04-02-2012, 12:17
ssirovica's Avatar
ssirovica ssirovica is offline
Programming Captain
AKA: Sasha Sirovica
FRC #1458 (Red Ties)
Rookie Year: 2010
ssirovica is an unknown quantity at this point
You can also use this code to print to the dashboard on the Classmate or another PC. Here is an example:
PHP Code:
public void printToClassmate(){
DriverStationLCD driverStation DriverStationLCD.getInstance();
driverStation.println(DriverStationLCD.Line.kUser21"Left Speed: " Double.toString(leftEncoder.getRate()));
driverStation.println(DriverStationLCD.Line.kUser31"Right Encoder: " Double.toString(rightEncoder.getDistance()));
driverStation.println(DriverStationLCD.Line.kUser41"Axis output: " Double.toString(leftStick.getRawAxis(4)));
//driverStation.println(DriverStationLCD.Line.kUser5, 1, "URF: " + Double.toString(ultra.getRangeInches()));
       //driverStation.println(DriverStationLCD.Line.kUser4, 1, "Gyro angle: " + Double.toString(gyro.getAngle()));
driverStation.updateLCD();
Just make sure to change kUser after every line because that is the line number it prints on, and call this method in your main While loop.
Computers run on smoke. When you let the smoke out the computer stops working.
Unread 04-02-2012, 15:43
FRC #1849
I searched for "netconsole" on the classmate from the Windows start menu but it didn't find anything. I had one of the faulty USB classmate images, so I had to install the driver station and cRio images from a download and maybe I didn't get the netconsole that way?
As for using the diverStationLCD, ssirovica, I need the ability to print out lots information linearly, far more than the 6 or so lines I get out of the driver station.
Is there some way I can just manually connect a terminal to the stdout on the cRio to get those messages? The development machine runs Ubuntu Linux, so it has a powerful terminal.
Unread 04-02-2012, 16:04
I believe NetConsole is installed with the Utilities Update, but I don't remember for sure. I know someone has posted a cross platform Python version somewhere here on CD that will listen on the right UDP port and print whatever it hears, but I don't have time to dig it up right now.
Unread 04-02-2012, 16:06
FRC #1849
Okay, I'll go search for that cross-platform UDP listener because that would be great. Thanks.
Unread 04-02-2012, 18:58
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Type http://10.te.am.2 into a web browser on a computer that is configured for the same network as the cRIO, where te.am is the usual team number IP.
The button with the monitor (see below) on it on the left side is the cRIO terminal window. You have to check "refresh repeatedly" on the bottom for real time.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
