Go to Post Then use Newton's handy-dandy 2nd law (Force = mass*acceleration) to solve... - Chris Hibner [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:32
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Hanging Around
Posted by Matt Hugo.
Coach on team #397, K I T, from Flint Southwestern Academy and Delphi Automotive Systems.
Posted on 1/13/2000 7:26 AM MST
If you are hanging from the bar on the ramp and touching the side supports (but not using them for support in any way) do you still get the points for hanging?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Hanging Around
Posted by Justin.
Other on team Blue Lightning Alum from RWU sponsored by FIRST-A-holics Anonymous.
Posted on 1/13/2000 8:36 AM MST
In Reply to: Hanging Around posted by Matt Hugo on 1/13/2000 7:26 AM MST:
I think that if you look at Update #1 Q3 that might give you some clarfication. Q3 also refers you to rule GM23. It seems to me like what they're getting at is they only want you hanging and they don't want you using any other part of the goal as a support. Which means that the potential for the whole pendulum effect is still there and still haunting.
Hope this Helps,
-Justin
#0047 (ChiefDelphi)
Re: Hanging Around
Posted by Jon.
Engineer on team #190, Gompei, from Mass Academy of Math and Science and Worcester Polytechnic Institute.
Posted on 1/13/2000 9:24 AM MST
In Reply to: Re: Hanging Around posted by Justin on 1/13/2000 8:36 AM MST:
At kickoff they said you're allowed to be touching the side supports if it happens accidentally, but you cannot design a system to interact with those supports intentionally.
right? or was i just hearing things?
#0047 (ChiefDelphi)
Re: Hanging Around
Posted by Justin.
Posted on 1/13/2000 9:40 AM MST
In Reply to: Re: Hanging Around posted by Jon on 1/13/2000 9:24 AM MST:
Jon,
I don't specifically remember what they said about that at Kickoff. However I think it is within the spirt of FIRST that if when you arrive in the hanging postion it happens that you do it in such a way that the sides of the goal prevent you from moving I don't think they'll have a problem with that. I think more what they don't want is a device that will prevent you from moving. Based on what I've seen I'd say your interpretation is correct so long as you don't have a device that comes out of the machine and latches on to the goal to keep you from moving. Of course it will as always be up to the refs to determine what they consider accidental.
-Justin
[IMG] code is Off
Metal strips on ends of bridge archiver 2001 2 23-06-2002 23:35
what do you think was... archiver 2000 15 23-06-2002 23:14
'My Favorite Part was.....' archiver 2000 30 23-06-2002 22:48
Hanging on the pole archiver 2000 3 23-06-2002 22:48
'hanging' ? archiver 2000 3 23-06-2002 22:35
