How to deploy code?
Hi Guys,
I just want to know how to deploy the code to the robot. I know how to run it but i want to keep a code on the cRio. I looked everywhere but still can't find it. I appreciate your help. -Andrew |
Re: How to deploy code?
Make sure the robot is turned on and physically connected and navigate to Build Specifications> FRC Robot Boot Up Deployment. Right click it and Build. When that finishes right click it again and Deploy. Also if you didn't click automatically run as startup when you imaged the cRIO Right click it a 3rd time and run as startup.
Skip the "Deploy" step.
I don't know about anyone else, but this is what I do:
1. Plug a crossover cable into the cRIO (unplug the bridge cord or whatever that is called (ethernet cable) that is currently in the cRIO and place that instead) and into the ethernet port on the PC that contains the code 2. Turn the robot on 3. Open the program cRIO Imaging Tool, and apply "controller settings" (or something like that) once it's detected the cRIO 4. Go the project folder for your program in labVIEW, find "Build Specifications" (usually at the bottom, never seen it anywhere else ._.) and right click on it 5. Click on "Build" 6. Once complete right click on "Build Specifications" again and this time click "Deploy" 7. Turn the robot off, and unplug the crossover 8. Place everything where it needs to be (ethernet back into the cRIO, etc) It seems to stay on there for me, but I know last year we had to do something like this: Quote:
I tried all those steps that all you guys posted but it still not working. When I reboot the robot, it says "No Robot Code." Is there any other way to deploying the code so each time I on the robot the code will be there.
-Andrew |
I personally find the distinction between on and off with those switches very confusing so that may be your problem.
