Go to Post Really heavy snow is different in Minnasota and Oklahoma... It has to be pretty bad up there. - thatoneguy23 [more]
Unread 04-02-2012, 14:05
TRiGa's Avatar
TRiGa TRiGa is offline
FRC #1748 (Lab Rats)
Rookie Year: 2012
TRiGa is an unknown quantity at this point
Mounting a CIM motor wheels
Hello,
I represent Team 1748; if anyone can help us. We are trying to mount a CIM motor directly onto the wheels.
We would be of great appreciation if you can help us out.
Eeveelution
Eevee
Vaporeon
Jolteon
Flareon
Espeon
Umbreon
Leafeon
Glaceon
Unread 04-02-2012, 14:18
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Mounting a CIM motor wheels
Andymark sells keyed hubs.
http://www.andymark.com/Hubs-s/215.htm
Just look for the right size for your wheels, and the key in the CIM.
Unread 04-02-2012, 14:19
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
This little guy makes it easy: http://www.andymark.com/product-p/am-0320.htm
I hope this is for some sort of scoring mechanism and not the drive... Direct CIM drive is not the best idea in the world...
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 04-02-2012, 14:26
TRiGa's Avatar
Rookie Year: 2012
its for scoring not for driving but THANKS
Eeveelution
Eevee
Vaporeon
Jolteon
Flareon
Espeon
Umbreon
Leafeon
Glaceon
Unread 04-02-2012, 15:10
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Could you use 2 short pieces of reinforced rubber tubing from an auto-parts store? One piece fits the CIM shaft, the other fits the wheel axle (live axle), and the 2 are connected with a tubing adapter.
Unread 04-02-2012, 16:12
mrlg220's Avatar
mrlg220 mrlg220 is offline
FRC #3464 (Sim-City)
Team Role: Mechanical
Rookie Year: 2011
mrlg220 is an unknown quantity at this point
We also had this issue a few weeks ago. We actually didn't use either of the key hubs; rather, we bought the andymark 250 hub (.25 inch hole). We drilled the hole open just so it fit onto the shaft (.313" or so?). We then added a set screw on the side. Hammered it on and it works perfectly. Note that for the kop wheels you'll be fine, but the plaction wheels need special fasteners (to attach to the hub).
Unread 04-02-2012, 18:38
DonRotolo's Avatar
Back to humble
FRC #0832
8 millimeters
