Thread Tools |
Rating:
Display Modes |
Cheap small gear source
Posted by Allen Smith.
Engineer on team #7, Knights, from Parkville High School and Black & Decker/AAI/Raytheon. Posted on 1/13/2000 6:53 PM MST It is possible to buy a gear from a Black and Decker service center that will press on to the Fisher-Price motor. Part #148579-00 $2.35 is available at your local parts dealer, just look in the yellow pages under power tools, repair. While they probably don't stock it they should be able to get it in less than a week. This gear has 10 teeth at a diametral pitch of 44 and mates with part #148373-00 $3.95 which is a cluster gear with 53 teeth at 44 DP on one side and a pinion of 8 teeth at 36 DP on the other side. This gear can mate with any of the following 3: part #148553-00 $7.05, 47 teeth; part #148561-00 $10.75, 35; or part #91246-00 $2.65, 17 teeth. The first two gears I mentioned are powdered metal, the next two are cut steel, and the last one is nylon. E-mail me if you want more details |
How about some pics of this, please?
Posted by nuts4first.
Engineer on team #340, GRR - Greater Rochester Robotics, from Churchville-Chili and Nortel Networks. Posted on 1/21/2000 12:58 PM MST In Reply to: Cheap small gear source posted by Allen Smith on 1/13/2000 6:53 PM MST: Can anyone supply some pictures of this modification? Or, a detailed description. I assume the gears that you are replacing are inside the gear assembly some where between the motor output shaft and the transmission hub. -Nuts4First |
Not simply replacement gears
Engineer on team #7, Knights, from Parkville High School and Black & Decker/AAI/Raytheon. Posted on 1/23/2000 6:15 PM MST In Reply to: How about some pics of this, please? posted by nuts4first on 1/21/2000 12:58 PM MST: These gears are not drop in replacements, you would have to fabricate a new gearcase |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| Possible Edurobot Gears Source | Adam Y. | Robotics Education and Curriculum | 2 | 13-12-2002 15:27 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
