Go to Post Part of being an effective leader is knowing your own personal limits. - artdutra04 [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 04-02-2012, 18:21
Censen.Morris Censen.Morris is offline
AKA: Michael
FRC #2403 (Team Plasma)
Rookie Year: 2010
Censen.Morris is an unknown quantity at this point
Exclamation NEED HELP wiring Allen-Bradley Right Sight sensor
We are very confused at the moment...
It is in team 2403's plan to use the Allen-Bradley Right Sight light sensors to inventory how many basketballs we have stored. We have figured out exactly how to use them/how they work in various tests and have calibrated the sensors to our specifications. Unfortunately the sensors are not functioning properly with our robot.
We have each light sensor wired into a digital input with the cables soldered together as follows:
Sensor - Digital Input Cable
White - White
Brown - Red
Blue - Black
Black - Empty
When we turn the robot on and launch autonomous the sensors do not light up like they did when we tested them - they don't light up at all.
Anyone's help would be greatly appreciated.
Unread 04-02-2012, 19:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: NEED HELP wiring Allen-Bradley Right Sight sensor
The sensor output only outputs 5 volts. The sensors need at least a 12 volt nominal supply. You can ignore the 5 volts and go straight to the Power Distribution board, or a 24 volt solenoid breakout, as that provides a constant voltage, whereas the Power board tends to fluctuate.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 04-02-2012, 20:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Once you have wired up power properly, only the white (or black, your choice) wire needs to go to the DIO signal pin on the Digital Sidecar.
Unread 09-02-2012, 17:59
AKA: Michael
Rookie Year: 2010
Talking Re: NEED HELP wiring Allen-Bradley Right Sight sensor
Thank you, we tried splitting the cable into a digital input and direct power distribution and that worked.
