Go to Post You are what this world needs: a hero kids of all ages and backgrounds can look up to. I am a better person today than before I met you, because of how you touched my life. I thank-you. - Paul Copioli [more]
Unread 04-02-2012, 19:59
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
Wind River corrupt media?
I am having difficulty installing wind river on our classmate PC.
I reimaged, then started following the wind river installation instructions.
(I did not start Wind River after the installation of disc 1)
When I start setup on disc 2, I get the error: "This media is corrupt: See "setup.log" ...
In the setup.log, it shows some files that cannot be accessed:
.../images/CDR-R158490.1-2-00
.../images/CDR-R158491.1-2-00
and 7 others.
On my disc 2, I have a set of directories are called:
.../images/cdr_r158.1_2
.../images/cdr_r148.1_1
etc.
I do not have a USB drive, so I am copying the contents from the DVD on my Ubuntu Linux machine. I do not have access to a windows machine here.
I can understand that the file name case might be changed, but the names should not change... Except now I notice that the filenames I see are in 8.3 format.
Would it work to rename the directories that I have to the ones that it says it is missing?
I think there is a lot more that is cut off... I have a directory called "installe" not "installer" so I don't think this is going to work.
Anyone else have this trouble? Find a way around it?
