Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 04-02-2012, 20:27
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
Rookie Year: 2011
chi-town-biker is an unknown quantity at this point
Battery Best Practices
I have a few questions about batteries at competitions.
1) How many batteries do you take?
2) How many chargers?
3) How do you test, charge or otherwise prepare your batteries for competition?
4) Do you do anything special between matches to keep your batteries ready?
5) Any other advice?
Unread 04-02-2012, 20:43
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Battery Best Practices
Our team usually takes 4 batteries, and that gets us through usually pretty well. As far as chargers, I would suggest at least one per battery, but you could get away with just 2 or 3 chargers if you must. For testing the batteries at competition, we have a device (I think it's an old automotive battery tester) that puts the battery under load and reads it as good or weak. To charge the batteries, we charge them over night before and during competitions, and during the day on Fridays and Saturdays, we change it to the full 6AMP charging rate and try to always keep one full charged battery on hand. We also separate full charged batteries from batteries that need to be plugged in. If there is ever an open charger, we plug in a battery unless the battery is >95%.
If it comes down to elims, you can always ask other teams if you can borrow batteries/chargers. They'll be happy to loan you for the afternoon.
Hope it helps!
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 06-02-2012, 07:42
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
For testing, we have a voltmeter with the tips of the cables cut off and soldered to a battery connector. We normally bring one charger per battery, and about seven to the competition (though this is probably a bit overkill). Some major advice: if the battery drops below 10.5 volts, it will get damaged! I would advise to check the batteries pretty frequently, and make sure they don't go below 11v. Also, when they charge, their max is 14.4v, but it will drop to 13.8v (its max rest charge) afterwards, so don't freak out if they seem to charge and then drop again!
I would put a signature here, but that's too mainstream
Wait a moment...
Unread 06-02-2012, 07:58
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
The Andymark Battery Plugs provided in the KOP are an excellent way to indicate that a battery is charged.
Unread 06-02-2012, 08:19
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
1) We generally take as many batteries to a competition that we can. In previous years this number has ranged from 4-6 'competition' batteries and 2-3 'Practice/Testing' batteries.
2) Recently, we've taken 3 Chargers to most competitions, this is usually enough at most regional events until later in eliminations when battery changes happen more frequently.
3) In previous years we never had a scientific method of testing batteries, we've usually just relied on pre-season robot testing to find out what batteries are the best.
4) After a match ends and the robot is brought back to the pits that battery is immediately put on the charger and one of the charged batteries is staged to go into the robot for the next match.
5) Sometimes you'll come across an older battery or two that won't quite make it through an entire match but will hold enough of a charge to run the robot for some period of time. We usually set these batteries aside for pre-match testing and practice field use. In years that we've used the compressor, we'll often use these batteries to initially charge the pneumatic system. If you don't have enough batteries to do this, then you can always leave the battery from your previous match in your bot up until it's time to go into que for your next match and use that battery for testing and pneumatic charging. No reason to drain a fresh battery before a match just to see if everything's working, IMO.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 06-02-2012, 09:03
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
Team 612 takes 9 batteries and usually 4 to 5 chargers. Our logic is that with 9 batteries, that is normally the maximum amount of matches a team would play in the playoffs. 3 QF matches, 3 SF matches, 3 Finals matches. Its also nice to have extra batteries just in case an alliance partner needs one.
Unread 06-02-2012, 09:41
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
1640 brings around 9 batteries and 7 chargers to competition. This lasts us through finals if none break, and usually gives us one to loan to an alliance partner or opponent.
My number one recommendation is to clearly number all your batteries and chargers. We also test all the batteries beforehand with a CBA III and test any questionable chargers as well.
At competition, we use a comprehensive match chart which includes the match number, battery and charger numbers, and battery performance (namely actual starting and final voltage from the dashboard if they're abnormal). We also keep them all carefully sorted in the pit, using a standard sequence as well as checking the charge lights on the SC-600A (highest amperage). We've also purchased a Battery Beak, which we've been using in the shop and plan to use in the pits. We looking to build a battery cart in the off-season, as the current setup is sort of table-space intensive.
Unread 06-02-2012, 09:42
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
You want to keep up with your batteries. Buy this http://www.crosstheroadelectronics.com/Beak.html
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 06-02-2012, 09:55
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I'm using one of these this year. We only have four batteries at present, so knowing the capabilities of each is critical. I have recorded measurements of all batteries at well-defined points. E.g. after each use in a testing session, after each charge session, after each idle period. I expect to use the information as evidence that we need more batteries for competition.
My only objection to the device so far is that it comes with a lanyard (around the neck) that doesn't split. Safety hazard in a mechanical environment.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 06-02-2012, 10:50
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
I second this. We ordered one through AndyMark and have found it very useful to give a quick charge rate and reasonable idea of battery health.
Unread 06-02-2012, 14:27
Rookie Year: 2011
We bought a battery beak this year and think it’s great. If we monitor the internal resistance of our batteries over time using the beak, is that a fair substitute for a CBA III for a team on a budget?
Unread 06-02-2012, 14:37
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
Rookie Year: 2010
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
We are a team on a bit of a tight budget looking into a load tester. Does anyone have any experience with the attached relatively cheap tester from Harbor Freight?
http://www.harborfreight.com/100-amp...ter-90636.html
Unread 06-02-2012, 14:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Chad,
I would recommend that no team use the linked battery checker. The minimum load is 100 amps. While FRC robots can draw that much, the battery will likely show up deficient on this tester. In the hands of an inexperienced user this tester could cause some internal damage to the battery. The CBA can run a duplicate test to the manufacturer printed test to calculate amp hour rating. The CBA tests can be stored on the host computer and compared over time with the same battery or with all batteries. The Battery Beak is a quick tester that determines battery condition at 1 amp and at 15 amp and makes calculations to determine internal impedance and battery condition. The Beak is a good quick tester while the CBA tests over a two hour period. The Beak fits in your pocket and requires no special cable, the CBA does not fit in your pocket and requires a USB connection to a computer.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 06-02-2012, 19:35
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The Genesis NP18-12R battery (2012 FRC KoP) datasheet1 indicates that it is rated up to 150 amps, so in theory you could measure it with a 100amp load tester, but:
  1. The datasheet does not list any manufacturer specs at that high discharge rate, so any assessment based on testing done at that rate could only be relative to other batteries tested the same way.
  2. In the wrong hands, testing at 100amps could damage the battery or be a real safety hazard.
Use something else.
1 http://www.batteryplex.com/sheets/NP18-12R.pdf
  #15   Spotlight this post!
Unread 06-02-2012, 23:30
Captaindan's Avatar
Captaindan Captaindan is offline
AKA: Daniel
FRC #0364 (Team Fusion)
Team Role: Driver
Rookie Year: 2010
Captaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the rough
yes ours is still going strong after 2 years and an anderson connector soldered to it
