Go to Post You have to start at the bottom to get to the top, usually. - Kyle [more]
Unread 04-02-2012, 21:12
Alex Redman's Avatar
Alex Redman Alex Redman is offline
Zombots Lead Programmer
AKA: Alexander Redman
FRC #3013 (Zombots)
Alex Redman is an unknown quantity at this point
Motor/ Voltage Compensation
Does anybody have a way to compensate for when the voltage to a motor decreases so that we can keep the motor output constant?
Unread 04-02-2012, 22:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Motor/ Voltage Compensation
Are you trying to run the motor at a constant speed? You'll want to use a sensor so you can tell what the speed actually is and increase the power if it is too low.
Unread 05-02-2012, 01:32
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
We have a guide on closed loop control which you may find helpful:
http://team2168.org/index.php/resour...ntrol-tutorial
http://team2168.org
