Go to Post Parallax is evil. - RoboChair [more]
Unread 04-02-2012, 23:08
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Ramp approach
Here is our ramp approach test (team 842)
http://www.youtube.com/watch?feature...&v=JviKwBjEP1c
We have 16 lbs counter weight and 60lbs robot base, still have more work to do...
Faridodin "Fredi" Lajvardi KD7WKD
Unread 05-02-2012, 03:35
andycolletta andycolletta is offline
FRC #2102 (Team Paradox)
Team Role: Leadership
andycolletta is an unknown quantity at this point
Re: Ramp approach
Do you need the whole sheet of plywood? why is there a stack stopping the bridge from over turning?
Unread 05-02-2012, 08:32
AKA: Ledge
Team Role: Teacher
Re: Ramp approach
We were only concerned with bringing the ramp down, and we had to simulate the 15 lbs of counter weight from the otherside. It was our understanding that it takes 15 lbs to push the ramp down, so we made it so. the only problem was that our ramp did not take 15 lbs to push it down, hence the counter weight , hence the blocks of wood
Unread 05-02-2012, 10:05
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Re: Ramp approach
How does it work with bumpers in place?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 05-02-2012, 22:52
AKA: Ledge
Team Role: Teacher
Re: Ramp approach
Bumpers will be 5" off ground and will be just above bottom of ram. It should clear
