Go to Post its ok to have opinions- but why attack everyone elses who differs. - stevek [more]
Unread 05-02-2012, 13:13
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
Team Role: Mechanical
Rookie Year: 2011
swwrobotics is an unknown quantity at this point
Gear ratios for launcher
Has anyone found that magic gear ratio that works best for the launcher?
Our team tried doing a direct drive with the CIM motor but the ball did not go very far. I remember reading that a 2.7 to 1 gear ratio works best but I can't be sure. Any ideas?
Unread 05-02-2012, 13:15
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Gear ratios for launcher
We've been running 2 BaneBot 550s with 20:1's and they work beautifully. We may just be able to pull off our master strategy after all
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 05-02-2012, 13:19
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
The gear ratio depends heavily on the diameter of your end effector, assuming you're doing a roller/wheel shooter. Direct-driving with a CIM to a 1" roller is very different from an 8" wheel.
OP, care to provide any details? My team's experiments show that you should find the exit speed you need for your range, assume the ball will go 60%-70% of your theoretical tangential free speed, and gear accordingly.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 05-02-2012, 13:33
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
Our team is using 6in or 8in wheels for our shooter, I can't remember which one. (I'm not actually on the shooting team)
Unread 05-02-2012, 13:50
Rookie Year: 2011
We are doing a one-wheel design that uses the new six inch wheels that came in the kit of parts and a flap on the top to adjust the angle the ball comes out of.
We were just worried that a high gear ratio wouldn't have enough force to launch several balls and it would be hard to get back up to speed.
Unread 05-02-2012, 13:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The new kit wheels tend to tear up the balls, according to a couple of reports from teams who tried them. We're using a single 8" kit wheel from a year or two ago, driven by last year's FP motor with it's 19 tooth pinion, which drives an older FP plastic first stage gear from the FP gearbox. The ratio is 19:72, I believe. This gives us a pretty good range....
http://www.youtube.com/watch?v=81vOT2KY2ig
But the gear ratio you want will depend on a lot of factors, as others have mentioned.
Unread 05-02-2012, 14:54
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
How much compression were you putting on the ball?
Other than the fact that the tread pattern on the 2012 KOP wheels chews up the foam basketballs, any single-wheeled shooter with six inch wheels (when directly driven from a CIM) should easily be able to shoot the balls a more than adequate distance.
Simply changing the gear ratio won't solve this problem; the real problem is probably related to ball compression, shooter hood design, and/or misalignment/binding/friction in the moving parts of the shooter.
FYI: The 2.7:1 gear ratio is what is inside the CIMulator from Banebots. There will likely be a fair amount of teams using this gearbox this year, as this gearbox makes a 775 or 500-series motor "emulate" the output characteristics of a CIM motor. This allows teams without a lot of machining resources to keep their CIM motors in their drive train and use "emulated" CIM motors elsewhere on their robot.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 05-02-2012, 15:21
Rookie Year: 2011
Our mentor said the we should have as little amount of contact with the ball as possible to pervent too much deformation and loss of accuracy. So you're right, that definitely could be the problem. But just out of curiosity, would it be worth more to have a high gear ratio or a larger wheel diameter?
Unread 05-02-2012, 15:28
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
It's true that you should have as little contact with the ball as possible, but you still need some minimum amount of contact, otherwise you won't impart much energy to it. Many teams seem to have found that 1-2" of pinch on the ball will work well.
With a 6" wheel you could be looking for 2,000-5,000rpm axle speed, depending on what range you want. the actual ratio will depend on what motor(s) you're using.
Unread 05-02-2012, 15:40
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Has anybody posted test data anywhere that includes wheel rpm, wheel diameter, squeeze, launch angle, and distance?
[edit] and wheel moment of inertia, if available? (yeah, I know: dream on) [/edit]
I've been keeping an eye out, but haven't seen anything yet. It would be most useful as a sanity check for some of the calculations.
Unread 06-02-2012, 01:02
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
We took a decent amount of data with ball compression, I'll see if I can't dig that up and compile for public posting.
We're gearing for a top speed at the wheel edges of about 80 ft/s (54 mph!), since this is about double the speed of 40 ft/s that worked well for basically any shot in the near half of the field in our testing. So for a 4" wheel that's a 5:1 off of FPs (0673) and we have nearly the equivelant of 4 of them (2 FPs, 2 550s), so we're making up for lost torque (see here for more of the reasoning behind that). We're using the same 8" plaction wheels we tested with because that tread seemed to work better than others we tried briefly. I pushed for wheels smaller than the ridiculous 8 inches, but nobody ever tested anything smaller (we have screwed up ways of setting priorities, working on fixing that...) and people were worried about differences in traction with smaller wheels, we stuck with 8". The reasoning for smaller wheels was mostly weight, with a marginal benefit in how the frame could be layed out (more freedom), as well as just not having ridiculously huge wheels. But no one listens to me anyway... In any case, with our 8" wheels we have 10:1 total reduction off of 2 FPs and 2 550s in the works.
Unread 06-02-2012, 01:16
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Two weeks ago I made a pitcher using two rollers made out of 2.5" PVC covered in wedge top tread. This was powered by two 775s on banebot 46-1 gearboxes with no chain reduction. The compression of the balls was about 2 inches.
I would be comfortable shooting from half court with this thing. It is also good for rapid fire, the 775s have so much torque that the rollers will spin at a steady speed no matter what.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 05-02-2012, 15:50
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
FIRST Team 1296 is trying 2 FP 801 motors at 6:1 and 2 AM motors at 4.64:1 driving 2 8" wheels (both under the ball) - have not got it running yet, a proof of concept with a CIM at 3:2 worked nicely compressing the ball 1-1/2"
HTH
Fast, cheap or working - pick any two!
Unread 05-02-2012, 17:49
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
Rookie Year: 2010
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
Team 166 is direct driving 2 axels with 2 8" wheels each. Each axel has a cimulator with 2 rs-550 motors each. We have not clocked its top rpm yet but the wheels spin quite fast as you can see in this video: http://www.youtube.com/watch?v=YtiK87pE_9U
We don't know the range of the final shooter yet, but the prototype could shoot 46-50 feet, the prototype was direct drive cims instead of cimulators.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
  #15   Spotlight this post!
Unread 05-02-2012, 23:10
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
We're making very consistent shots from key range with AM motors and planetary gearboxes, though the spin-up time between shots is too long. We're working on that problem now!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
