Go to Post Nobody wins a Regional on Thursday. - Bill Moore [more]
Unread 05-02-2012, 13:34
Gnome2013's Avatar
Gnome2013 Gnome2013 is offline
Gnomies
FRC #2013 (Cyber Gnomes)
Gnome2013 is an unknown quantity at this point
Axis Camera Won't Stay Configured
Our axis camera works tight after we configure it but when we turn it off and turn it on again it takes 30 minutes to turn green then it doesn't work and the only way to get it to work again is to reset it and reconfigure it. What could be wrong with it?
Unread 05-02-2012, 14:46
mjveld1018 mjveld1018 is offline
AKA: Matt
FRC #0292 (PantherTech)
mjveld1018 is an unknown quantity at this point
Re: Axis Camera Won't Stay Configured
Make sure the (very easy to press) reset button is not being pressed. If that is held down when power is cycled, the camera is reset. I think it also stays orange while it's held down.
Unread 05-02-2012, 14:54
There was also an issue with the configuration tool that was released at kickoff. A newer version is available on ni.com or you can configure it by hand. For details, search for posts about the topic written around Jan 12th.
Greg McKaskle
Unread 05-02-2012, 15:26
Joshuamunson Joshuamunson is offline
FRC #2996
Joshuamunson is an unknown quantity at this point
I don't know if this helps or not, but we had a problem with the camera loosing it's ip address every time we would power cycle it. If I remember correctly you plug the camera in and go to its default ip (ours was 192.168.0.90) then go into setup, create an account FRC with password FRC. then set the ip to manual and give it an address that wont interfere with anything else, then save it.
Hope this helps!
Unread 06-02-2012, 14:56
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
Greg McKaskle
We had this problem as well and the new camera setup tool fixed our problem. I've also read on CD that manually configuring the camera (instead of using this tool) works, but I haven't tested that.
You can find the utilities update here: http://joule.ni.com/nidu/cds/view/p/id/2262/lang/en
