Go to Post "If you can't hurdle, you can't win." "Remember to practice your obnoxious amateurism." . - dlavery [more]
Unread 05-02-2012, 17:23
ArmandoSal ArmandoSal is offline
FRC #0996
ArmandoSal is an unknown quantity at this point
Forced needed to get on Bridge
Hello, I am just wondering if anyone has found out the force needed to tilt the Bridge so that a robot can get on it. Thanks.
Unread 05-02-2012, 17:32
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Forced needed to get on Bridge
This was posted in another thread i saw a while back as 16 to 18 lbs of force on the most outer part of the bridge. I am not sure of these measurements however, Could someone confirm this?
Expect the best, Prepare for the worst
Unread 05-02-2012, 20:02
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
The weight of 2 batteries at halfway is needed to tip, so ~1 battery's worth is needed at the edge. That's about 13 pounds, so design for 20 lbs to be on the safe side.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 05-02-2012, 20:18
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
That's about right. To clarify, it takes ~59 lbf-ft of torque to tip the bridge.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 05-02-2012, 21:44
AKA: Jon
for teams that have matched their bridge to the specs of competition. how did you adjust the balance of your bridge? did anyone recreate the 16-18 lbs on both sides while keeping the bridge balanced? any info would be greatly appreciated.
Unread 05-02-2012, 21:54
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
With an extra 160 pounds of concrete blocks mounted underneath the deck, our wooden bridge now passes the "two battery" test.
Unread 05-02-2012, 22:01
jdunston94 jdunston94 is offline
FRC #3357 (C.O.M.E.T.S.)
Rookie Year: 2011
jdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the rough
instead of putting aton of uneeded weight on the underside of the bridge we just put surgical tubing
and it is right around 18lbs of force perpendicular to the bridge to push it down
Unread 05-02-2012, 22:18
AKA: Jon
How did you attach the tubing?
Unread 05-02-2012, 23:56
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
We took eye hooks and screwed them into the bottom of the bridge. Then we adjusted the tubing till it met the specs.
Unread 06-02-2012, 00:10
AKA: Jon
alright thanks. i will try that on monday
Unread 06-02-2012, 10:53
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
This will not actually yield the competition bridge dynamics. How much it is off will be situation-dependent. In short though, you're now using spring force (F=-kx) rather than distributed bass to balance the moments. This means that, while you may pass the battery test, as your bridge moves, the moment caused by the spring force will not fully mimic what the simply heavier competition bridge would do. It probably won't affect your bridge lowering tests, but if you're practicing (much less autonomously programming) balancing on it, don't count on the results being the same unless you've tested it.
Unread 06-02-2012, 15:17
AKA: Jon
could anyone who has done this post a picture of the bridge with the surgical tubing set-up?
Unread 22-02-2012, 10:29
dcreed@epic.com dcreed@epic.com is offline
FRC #3692
dcreed@epic.com is an unknown quantity at this point
I'm confused... some people are saying 16-19lbs of force at the end of the bridge and then someonw say the ~59 lbf-ft of torque to tip the brige.. so say if using a window van motor with 25.8 ft-lbf applied to the end of the bridge? Would this tip the bridge or not?
Thanks,
Dan
Unread 22-02-2012, 11:35
Software Architect
Where's the confusion? The end of the bridge is about 40-48 inches from the hinge point, depending on which end, so 59 lb-ft of torque would be between 15 and 17.5 pounds.
How much force are you applying to the end of the bridge? A one-foot-long direct-driven rod perpendicular to the motor shaft could work. A two-foot-long rod would not.
  #15   Spotlight this post!
Unread 22-02-2012, 11:39
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
My opinion. Don't even think of trying to drive up to the bridge and then use an arm of some kind to tip it down. You have to have extremely good depth perception to make that work unless you have some way of letting the robot do it by itself. Remember, most cases you are on the other side if the bridge at some distance and partially concealed by the bridge.
Better, lower a ramping device with an over center latch and just drive up to the bridge. Let the weight of your bot push the bridge down.
see here
http://s1121.photobucket.com/albums/...t=100_0013.mp4
Hope that helps
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
