Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 05-02-2012, 19:14
Micah Chetrit's Avatar
Micah Chetrit Micah Chetrit is offline
FRC #3276 (NSR)
Rookie Year: 2010
Micah Chetrit is on a distinguished road
Lighting up the vison targets?
This is my first year using the camera tracking software. I recently purchased this as was suggested by this thread. Upon receiving it and turning it on, it seems to be too wide of a viewing angle to light up the targets enough.
Have teams need to light up the targets in prior years? If so, was that amount of light enough? If it isn't, is there an easy way of focusing the light?
Any general suggestions for camera tracking?
Thanks a ton!
Unread 05-02-2012, 19:44
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
Rookie Year: 2007
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Lighting up the vison targets?
I'm using the one from first choice (which I think is the one you bought), and it works fine at long distance (field length) for me
Unread 05-02-2012, 19:54
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You don't really want to focus the light to tightly in one direction. It needs to illuminate the entire field of view of the camera in order to be most useful. The spread from the LED chips on those light rings is just about right for our application.
Unread 05-02-2012, 19:57
What leads you to determine that it is not enough light? Did you look through the center of it or mount it around the camera lens?
Greg McKaskle
Unread 06-02-2012, 14:33
FRC #3276 (NSR)
Rookie Year: 2010
Greg McKaskle
I have not done any work with the camera with the light mounted yet, but I plugged it in, and it only gives the tape a dim green (color I bought) rather than the bright color I expected. I didn't know that it is enough for the NI software.
Unread 06-02-2012, 14:37
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
The targets are made of retroreflective tape. When viewed from an angle, it doesn't look like the LEDs are putting out much light. But try looking through the hole in the center and you will find the targets light up like Christmas trees.
Unread 06-02-2012, 14:46
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
We also bought the FIRST choice green LED ring. At first we thought it wasn't bright enough because the target only looked a little brighter with the LEDs on, but when we extracted the green color plane from the image the target was well illuminated and easy to find (with a vision algorithm). Don't write off the green LEDs until you've done that.
Unread 06-02-2012, 14:58
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
We did a little test to see how far off axis you could be and still see the light being reflected back to the source. We wanted to know if the color could be polluted by a robot right next to yours with a different color light. We found that as little as 6 inches off axis was enough to SIGNIFICANTLY reduce the reflection. By 12 inches, it was gone!
Look through the center of the ring, where your lens should be, and you will see the light!
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 06-02-2012, 19:43
FRC #3276 (NSR)
Rookie Year: 2010
Wow! That makes a big difference! I didn't even think about looking through the center.
Unread 07-02-2012, 13:40
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
I was confused by this, because I initially thought that this tape would reflect in a broad bell-curve-shaped distribution centered around the angle of reflection of the light source. This came from a poor understanding of the meaning of retro-reflectivity.
Then I read this writeup about the construction and physics of retro-reflective tape: http://dr650.zenseeker.net/ReflectiveTape.htm
Unread 20-02-2012, 10:58
Sefunx Sefunx is offline
FRC #0078
Sefunx is an unknown quantity at this point
Lightbulb Re: Lighting up the vison targets?
Our team (78) was able to secure, from ebay, some surplus green traffic light LEDs. They provide tons of light, (don't look at them...) but you may have to contend with an overheating problem... we almost melted through a camera... Its about 9 lights on a square panel, VERY USEFUL!!!
Unread 21-02-2012, 08:59
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You may have an issue with blinding your alliance partners. Remember this...
[R08]
Robot parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other Robots.
Examples of items that will violate this rule include (but are not limited to):
A. Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any drivers and/or coaches and/or interfere with their ability to safely control their Robot
B. Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction
C. Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities of another Robot, including vision systems, acoustic range finders, sonars, infra-red proximity detectors, etc.(e.g. including imagery on your Robot that, to a reasonably astute observer, mimics the Vision Target)
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-02-2012, 09:30
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
We refuse to put an ugly green light on our red and black robot, so we went with the amber light and it is working very well for us.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 06-02-2012, 14:57
Unsung FIRST Hero
Rookie Year: 1996
Micah,
The LED ring is intended to mount around the lens of the camera. The reflected light from retro-reflective tape is pretty impressive.
Al
WB9UVJ
www.wildstang.org
  #15   Spotlight this post!
Unread 06-02-2012, 23:39
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Rookie Year: 2010
Vikingtech2054 is an unknown quantity at this point
Thanks a ton!
Well our team bought a strip of led light that is flexible, the problem we had was the light source has to be as close to directly inline with the camera as possible, the retro reflective reflect directly back from where it is shined, so the close to your lens the better results youll get, so our team has the leds rapped right around the camera
