Go to Post And - I would never ever underestimate a rookie. Ever. - JaneYoung [more]
Unread 06-02-2012, 11:45
dwmcc dwmcc is offline
FRC #2192 (YAK Attack)
Team Role: Leadership
dwmcc is an unknown quantity at this point
How to make "sticky" joystick buttons?
Hello All,
I'm wondering how to create "sticky" joystick buttons, AKA an action (let's say set Relay to ON) is defaulted on at the beginning of a match, and pressing a specific button will toggle the relay ON or OFF, not momentarily changing it's status.
Thanks!
dwmcc
Unread 06-02-2012, 11:52
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
It's a little complicated. You need to start by detecting each button press as a unique event (instead of toggling for every loop during which the button is held down). At the end of every loop save the old button value. Only when the current value is pressed and the one from the previous loop is not pressed should you toggle the setting. Then you create a variable to store the state of your toggle and then you just change it every time we see a button press with the above logic.
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 06-02-2012, 12:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: How to make "sticky" joystick buttons?
Originally Posted by dwmcc View Post
Hello All,
Thanks!
dwmcc
http://www.chiefdelphi.com/forums/sh...30&postcount=3
