Go to Post The only fee our team charges is for your heart and soul. No refunds. - Koko Ed [more]
Unread 06-02-2012, 16:40
Derek012's Avatar
Derek012 Derek012 is offline
I miss my frisbees
FRC #4564 (Orange Chaos)
Derek012 is on a distinguished road
Exclamation Crio II IP Reset Error
Hey Teams,
I've been having issues with my teams cRio 2, we got interrupted in the imaging tool putting on the v43 of java, we got a timeout and then the cRio rebooted in safe mode. I tried to re image it after that from multiple IP's like 169.254.xx.yy and 10.xx.yy.2, the imaging tool wont let us change the IP because it says the IP DIP is on but its not on the Imaging tool, any suggestions?
Unread 06-02-2012, 16:43
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Crio II IP Reset Error
We had this happen to us, as well. Try running the 2012 FRC Imaging Tool in Windows XP Compatibility Mode (if you are on Windows 7). That did the trick for us.
Unread 09-02-2012, 14:35
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Originally Posted by Derek012 View Post
Hey Teams,
When you are imaging the cRIO, you should use a crossover cable with all other network devices (including wireless) disabled. Use the following settings:
IP Address: 10.xx.yy.1
Subnet: 255.0.0.0
Gateway: 10.xx.yy.2 (the address of the cRIO).
You make it sound like you are setting your computer's IP address to 10.xx.yy.2, which is wrong. If it prompts you that you are running in Safe Mode, after you image it you will need to image it again. This is true for the cRIO v1, I assume it is true for v2 but someone can correct me if I'm wrong.
