Go to Post To borrow a slogan from the last place KC Royals "It's Our Time" The curse will be broken! ;) - Alpha Beta [more]
Unread 06-02-2012, 16:41
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
Sun gear doesn't fit on shaft
I'm trying to fit http://www.andymark.com/product-p/am-0040.htm on http://www.andymark.com/product-p/am-0912.htm and it's not working. We already went through a motor. It doesn't fit smoothly. Am I doing something wrong?
Unread 06-02-2012, 16:54
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Sun gear doesn't fit on shaft
These two items are designed to be pressed together. It takes even pressure directly along the motor shaft axis to do it. Many options are available to do this. An Arbor press or a vice make if fairly easy. The key is to keep everything in a perfectly straight line. Any off axis pressure is going to bend your motor shaft. Make sure you are supporting the back side of the motor shaft against the vice.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 06-02-2012, 17:12
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
See this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=101825
