Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:35
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Aluminum Tubing
Posted by Mckinley.
Student on team #368, Mahimahi, from Mckinley High School and NASA Ames.
Posted on 1/14/2000 11:13 PM MST
In the appendix @: Additional Hardware List in the Structural Section does extruded aluminum include aluminum tubing?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Aluminum Tubing
Posted by Raul.
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 1/14/2000 11:32 PM MST
In Reply to: Aluminum Tubing posted by Mckinley on 1/14/2000 11:13 PM MST:
Although not the cheapest way to make tubing, some aluminum tubing is extruded. Let's be realistic - No one will question whether the tubing you got was actually extruded or not.
Raul
#0047 (ChiefDelphi)
Re: Aluminum Tubing
Posted by Dan.
Student on team #10, BSM, from Benilde-St. Margaret's and Banner Engineering.
Posted on 1/15/2000 8:38 AM MST
: In the appendix @: Additional Hardware List in the Structural Section does extruded aluminum include aluminum tubing?
In a previous message Joe Johnson said he checked, and it counts. So no one should give you trouble about your tubing . .
:-Dan
[IMG] code is Off
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
Definition of aluminum extrusion...? kangarue23 Technical Discussion 4 25-01-2002 16:53
does small parts sell rectangular aluminum tubing mnkysp6353 General Forum 2 09-12-2001 01:28
