Go to Post The thing about working hard, is you can always work harder. The thing about being great is you can always be greater. - JVN [more]
Unread 06-02-2012, 18:56
Bennett Bennett is offline
FRC #2977 (Sir Lancer Bots)
Rookie Year: 2012
Bennett is an unknown quantity at this point
Camera Tracking Problems...
With this code we get an image from the camera but we have an issue with trying to get the camera to track and print out the results, any ideas? thanks.
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.DriverStationLCD;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.image.*;
import edu.wpi.first.wpilibj.templates.commands.CommandBase;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class RobotTemplate extends IterativeRobot {
    AxisCamera camera;
    BinaryImage sensorimage;
    CriteriaCollection cc;
    public void robotInit() {
        String camip = "10.29.77.11";
        camera = AxisCamera.getInstance(camip);
        camera.writeResolution(AxisCamera.ResolutionT.k640x480);
        camera.writeRotation(AxisCamera.RotationT.k180);
        cc = new CriteriaCollection();      // create the criteria for the particle filter
        cc.addCriteria(NIVision.MeasurementType.IMAQ_MT_BOUNDING_RECT_WIDTH, 30, 400, false);
        cc.addCriteria(NIVision.MeasurementType.IMAQ_MT_BOUNDING_RECT_HEIGHT, 40, 400, false);
        while (true) {
            try {
                ColorImage image;                           // next 2 lines read image from flash on cRIO
                image =  new RGBImage("/10ft2.jpg");
                BinaryImage thresholdImage = image.thresholdRGB(0, 0, 0, 0, 0, 0);   // keep only black objects
                BinaryImage bigObjectsImage = thresholdImage.removeSmallObjects(false, 2);  // remove small artifacts
                BinaryImage convexHullImage = bigObjectsImage.convexHull(false);          // fill in occluded rectangles
                BinaryImage filteredImage = convexHullImage.particleFilter(cc);           // find filled in rectangles
                ParticleAnalysisReport[] reports = filteredImage.getOrderedParticleAnalysisReports();  // get list of results
                for (int i = 0; i < reports.length; i++) {                                // print results
                    ParticleAnalysisReport r = reports[i];
                    System.out.println("Particle: " + i + ":  Center of mass x: " + r.center_mass_x);
                DriverStationLCD.getInstance().println(DriverStationLCD.Line.kMain6, 1, "Particle: " + i + ":  Center of mass x: " + r.center_mass_x);
                DriverStationLCD.getInstance().updateLCD();
                System.out.println(filteredImage.getNumberParticles() + "  " + Timer.getFPGATimestamp());
                DriverStationLCD.getInstance().println(DriverStationLCD.Line.kMain6, 1, filteredImage.getNumberParticles() + "  " + Timer.getFPGATimestamp());
                 * all images in Java must be freed after they are used since they are allocated out
                 * of C data structures. Not calling free() will cause the memory to accumulate over
                 * each pass of this loop.
                filteredImage.free();
                convexHullImage.free();
                bigObjectsImage.free();
                thresholdImage.free();
                image.free();
                } catch (NIVisionException ex) {
            // freeing the image. A.K.A. letting the image go so we can have more images
                //sensorimage = camera.getImage();
        CommandBase.init();
        // schedule the autonomous command (example)
        //autonomousCommand.start();
     * This function is called periodically during autonomous
        Scheduler.getInstance().run();
    public void teleopInit() {
		// This makes sure that the autonomous stops running when
		// teleop starts running. If you want the autonomous to
		// continue until interrupted by another command, remove
		// this line or comment it out.
		//autonomousCommand.cancel();
     * This function is called periodically during operator control
