Errors when I try to load code
I get these errors when I try to load my code onto the cRIO, does anybody know how to fix these? (I know I have to use the MAX, but I'm really new at this and I need more specific instructions.
Deploying IMAQ CreateIMAQ Create loaded with errors on the target and was closed. LabVIEW: Failed to load shared library nivissvc.*:LV_Create:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target. Thanks! |
Re: Errors when I try to load code
You don't use MAX. That's just a generic message.
It looks like you are attempting to use some vision libraries that were not included with our FRC version of the cRIO. Is this from the output of the Vision Assistant? |
