Go to Post My son just said, "That's the kind of thing that you talk about in strategy sessions then say, 'nah, that would never really work.'" Un-be-freaking-lievable. - Rick TYler [more]
Unread 06-02-2012, 19:35
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Autonomous?
Hello -
Just wondering...When a team places there robot on the field to await Autonomous to begin, are they allowed to place their robot anywhere within their key?
I'm wondering if our Alliance decides that we aren't the best bot to use the Kinect, can I write an Autonomous script for a specific place(s) within the key, granted the Alliance agrees to the location?
Thanks.
Unread 06-02-2012, 19:37
Andrew Lawrence
Posts: n/a
Re: Autonomous?
I don't see why not. Your robot must start touching the key, so as long as that condition is met your should be fine.
Unread 06-02-2012, 21:17
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Re: Autonomous?
There is a difference between the "key" and the "top of the key." The key is the entire rectangle with the semi-circle, the "top" of the key is the semi-circle. I understand that in the rules, the semi-circle is called the key, but the common basketball term refers to the entire area. I just wanted to make that clear in case someone reading this isn't familiar with the FRC rules but knows basketball terminology.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 06-02-2012, 21:22
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Autonomous?
You may want to read the rules again. The key is only the top semi-circle. The rectangle is simply for looks. while talking about FIRST try to be talking about the FIRST field, not the basketball court. This is just confusing people.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-02-2012, 21:55
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Autonomous?
To the OP:
I would advise having at least three separate spots pre-programmed. Why three? Two other robots may want the exact same spot you do. Having three that don't contact each other ensures that you have at least one available even if both partners want a spot that you have pre-coded.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 06-02-2012, 22:21
AKA: Joe Lee
Rookie Year: 2010
Re: Autonomous?
Later in my post I acknowledge that the FIRST rules call the key the semi-circle. I was pointing that out for the benefit of those who are proficient in basketball terminology but may not know the FIRST terms. I'd hate to see a team program their robot based on a position in the rectangle because they think it's part of the FIRST key and have to rewrite their code or give up autonomous all together.
Joe
