Go to Post That settles it, no questions left. Water game. - Lil' Lavery [more]
Unread 06-02-2012, 19:38
ssirovica's Avatar
ssirovica ssirovica is offline
Programming Captain
AKA: Sasha Sirovica
FRC #1458 (Red Ties)
Rookie Year: 2010
ssirovica is an unknown quantity at this point
Screw Size
Does anyone have the screw sizes for the components in the electrical board?
These would include the Power Distribution Board, Digital IO Board, CRIO, Jaguars, Victors, and Spikes.
Thanks.
Computers run on smoke. When you let the smoke out the computer stops working.
Unread 06-02-2012, 21:35
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Re: Screw Size
Power terminals
Main Breaker: Terminal Supply CB3-SM-120 (pdf), 1/4-28 UNF studs, qty 2
Power Distribution Board: Andymark am-0865 (link): M6x1 studs, qty 2
Jaguar MDL-BDC24 (pdf): 6-32 UNC screw terminals, qty 4
Victor 884 (link): 6-32 UNC screw terminals, qty 4
Mounting hardware
Power Distribution Board: Andymark am-0865 (pdf): hole dia .257", qty 4
Digital Sidecar: Andymark am-0866 (pdf), hole dia .173", qty 2
cRIO-FRC (pdf): M4x0.7x16 flat head machine screws, qty 2
cRIO-FRC II (pdf): M4x0.7x25 flat head machine screws, qty 2
24V Power Converter: Current Logic 360-CPR (pdf), hole dia 7 mm, qty 2
Jaguar MDL-BDC24 (pdf): hole dia .175", qty 2
Victor 884 (pdf): hole dia .135", qty 2
Spike Relay Module (pdf): hole for #8 screw, qty 2
Diagnostic Signal Light: Rockwell Automation 855PB-B12ME522 (pdf): mounts into hole dia 22.5 mm
