Go to Post You're on a team, weren't you taught Gracious Professionalism? It doesn't only apply to competitions, it applies to the real world. - Zac Schofield [more]
Unread 07-02-2012, 09:12
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
vBulletin formatting escape character
I want to display a capital U inside square brackets.
But if I put a capital U inside square brackets, it gets displayed as lower case, like this: [u].
I believe this is because it is interpreted as the underline formatting command, without a matching /U command.
Is there an "escape" character in vBulletin which can be used to tell vBulletin to treat the [u] as a literal?
Unread 07-02-2012, 10:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: vBulletin formatting escape character
I don't know of a specific "escape" for VBCcode, but you already know the trick for fooling vBulletin into doing formatting the way you want. Quote this response to see how I used that trick to put a bracketed uppercase [U] into it.
Unread 08-02-2012, 16:10
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
-snip-
Heh, apparently [noparse][/noparse] tags don't work. Either way, they're still really useful!
FRC Team 93 Alumni
