Go to Post So we are able to run a very competitive and active robotics program. Sustainability, alas, is a month-to-month issue for us and is dictated by the space situation. This is okay today. Tomorrow could be different. We live like this. - Clem1640 [more]
Unread 07-02-2012, 19:52
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Joystick control of a window motor - Will not run
Hey I am having some problems getting a motor control to work in labview. I currently have a window motor hooked up to a jaguar in port 3 on the Digital Sidecar. I am trying to control it using my second joystick's 1 and 2 buttons. I have already tried searching for a solution in multiple threads but I only was able to confirm that my code should be working. Can someone take a look at it and let me know if I am doing something wrong?
Thanks!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 07-02-2012, 20:02
kuh-nig-its-EL's Avatar
kuh-nig-its-EL kuh-nig-its-EL is offline
FRC #1939
kuh-nig-its-EL is on a distinguished road
Re: Joystick control of a window motor - Will not run
Hello again.
Is this in teleop or is this an independent vi?
Unread 07-02-2012, 20:07
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
Oh wow, can't believe I missed that! =O I put it in Begin.VI
Thanks so much for pointing out the obvious! Now I can teach the programmers tomorrow what they were doing wrong!
Unread 07-02-2012, 22:08
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Just to clarify slightly, the Open for each device and a Reference Set for each device should be in Begin.vi. In Teleop.vi, you will want a Reference Get for each device (to link it back to the device you opened) and the rest of your code.
Unread 07-02-2012, 22:25
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
Yeah I got it, still a little new to labview but I am figuring it out. Begin.VI is where it initializes all of the 'global variables' of sorts and you can reference them from the other VIs. At least that is how I am beginning to understand it, if I am wrong please correct me!
Unread 09-02-2012, 16:46
vhcook's Avatar
Reader of Things
AKA: Victoria
I like to think of it as telling the software where the hardware is, naming things for later use, and initializing settings that aren't going to change later.
