Go to Post I'm not even going to bother...SEARCH! - sanddrag [more]
Unread 07-02-2012, 20:32
mikemascot's Avatar
mikemascot mikemascot is offline
SIR MASCOT
AKA: Mike handte
FRC #0316 (LuNaTeCs)
Team Role: Mascot
Rookie Year: 2011
mikemascot is an unknown quantity at this point
Question any tips on soldering a parallel circut?
any tips on soldering a parallel circut with leds? my team is making a mascot costume with led light up pants like (last years super bowl,with the black eyed peas) but i cant figure out how to get the bulbs to light up.
Unread 07-02-2012, 21:23
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: any tips on soldering a parallel circut?
protect the LEDs from excessive soldering heat. There are normally current limiting resistors for each LED. They are in series with the devices. Do you have device numbers for the LEDs? Better yet, a specification sheet for them? Somewhere on it will be listed the current rating for your devices. Typical values are 10 to 30 mA. If you try to have more current than that going through them, they will expire so fast, you won't see their death flash. If you have already hitched them to a battery of nearly any size, without using a resistor in series, you will need to replace them.HTH
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
