Go to Post Physics is weird sometimes, this is why we prototype. - Andrew Schreiber [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:37
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
The Pneumatics System
Posted by Matt.
Student on team #69, HYPER, from North Quincy High School and Gillette.
Posted on 1/16/2000 9:16 AM MST
How much psi is the pneumatics system? I heard 100psi but I also heard the most we could get out of it (at best) is 80 psi. Which one is it?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: The Pneumatics System
Posted by Ed Sparks.
Coach on team #34, Bob Jones High School / DaimlerChrysler, from Bob Jones High School.
Posted on 1/16/2000 11:01 AM MST
In Reply to: The Pneumatics System posted by Matt on 1/16/2000 9:16 AM MST:
My understanding is that it is a volume of compressed air @ 100 psi but that the kit includes a regulator that we are required to use that is set to 60 psi.
Ed Team34
#0047 (ChiefDelphi)
Posted by Rick Berube.
Engineer on team #121, Rhode Warriors, from Middletown H.S..
Posted on 1/18/2000 6:10 PM MST
In Reply to: Re: The Pneumatics System posted by Ed Sparks on 1/16/2000 11:01 AM MST:
: My understanding is that it is a volume of compressed air @ 100 psi but that the kit includes a regulator that we are required to use that is set to 60 psi.
: Ed Team34
Yes the regulator is 60 psi maximum, but can be regulated downward. What this means is that if you don't need the full 60 psi to operate your robot mechanisms, you can tune the regulator down and make the air in your tank last longer.
Rick
#0047 (ChiefDelphi)
Posted by Quentin Lewis.
Engineer on team #42, P.A.R.T.S - Prececision Alvirne Robotics Technology Systems, from Alvirne, Hudson NH.
Posted on 1/16/2000 2:58 PM MST
> Which one is it?
My understanding (from listening to the kickoff) was that the tank would be filled to 100 psi, but that there was a regulator inline that knocked it down to 60 psi for the user.
Does anyone know what the volume and size of the tank is? Is anyone going to use Pneumatics?
#0047 (ChiefDelphi)
Posted by Jon.
Engineer on team #190, Gompei, from Mass Academy of Math and Science and Worcester Polytechnic Institute.
Posted on 1/16/2000 3:20 PM MST
In Reply to: Re: The Pneumatics System posted by Quentin Lewis on 1/16/2000 2:58 PM MST:
i believe its 1.5 gallons at 9 atmospheres...
#0047 (ChiefDelphi)
Posted by Dan.
Student on team #10, BSM, from Benilde-St. Margaret's and Banner Engineering.
Posted on 1/16/2000 5:04 PM MST
In Reply to: Re: The Pneumatics System posted by Jon on 1/16/2000 3:20 PM MST:
Does anyone know (ballpark) the weight of the tank? Just from the scratchy webcast it looked like a heavy steel-walled type.
:-Dan
#0047 (ChiefDelphi)
Posted on 1/18/2000 6:07 PM MST
: i believe its 1.5 gallons at 9 atmospheres...
I took the pneumatics seminar at the kickoff. My notes say 1.5 gallons, ~9 atmosphere and ~110 psi.
The SMC representative was very careful to say ~110 psi because of elements beyond their control (such as temperature, humidity, etc.), your milage may vary. However, they were also very diliberate in saying that regardless of the exact pressure, everyone's tank will be pressurized the same, because SMC or FIRST will be filling the tanks at the competitions before each round. FIRST also warned us to make your tanks readily accessable in your design for this reason!
Rick
[IMG] code is Off
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
