Go to Post Hallry's back! Tell a Friend! - Tyler Olds [more]
Unread 08-02-2012, 00:41
el-zoroo el-zoroo is offline
Chief Operating Officer
AKA: Zuhair
FRC #2374 (Crusaderbots)
Team Role: Leadership
el-zoroo is an unknown quantity at this point
Initialize Module on Non-Default Slot
We have an extra Solenoid breakout we are trying to add. One is wired up for 24V and the other for 12V, and are having trouble initializing the second one. The first one is working perfectly fine. We encountered the same problem with the Analog breakout.
We initialize it like so, in Java:
Code:
Solenoid solenoid = new Solenoid(6,4); //Slot 6, Channel 4
Upon running the code, it immediately warns us that "Solenoid module 6 is not present" (or something to that effect). Subsequently, it throws an AllocationException.
Any help on initializing a module on its non-default slot?
Unread 08-02-2012, 00:42
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: Initialize Module on Non-Default Slot
Because of the new Module naming system, instead of slot number you need to call module number. so instead of 6 you would use 2.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 08-02-2012, 00:48
AKA: Zuhair
Thanks for the quick reply!
I had a suspicion about that when I was looking at the Javadocs.
But, how does the channel numbering work then? In other words, how would it know which module to go to if there are 2 solenoid breakouts?
Unread 08-02-2012, 00:56
Rookie Year: 2010
If using a 4 slot CRio, slot 1 is analog 1, slot 2 is digital 1, slot 3 is solenoid module 1. slot 4 is the second instance of whatever module you put in it. If using the 8 slot CRIO, 1,2 and 3 are the same as the 4 slot, and the slot 5 is analog 2, slot 6 is digital 2 and slot 7 is solenoid 2.
Unread 08-02-2012, 01:00
AKA: Zuhair
That makes a lot more sense!
Thanks!
Unread 16-02-2012, 15:05
Bpalms Bpalms is offline
FRC #1729
Bpalms is an unknown quantity at this point
Yeah Thanks a lot I was having this problem and I was ripping my hair out over this and this got it working for me.
Unread 19-02-2013, 17:58
silvereagle silvereagle is offline
AKA: Rob Eastmond
FRC #3405 (Maple Mountain Eagletronics)
Team Role: Coach
Rookie Year: 2010
silvereagle is an unknown quantity at this point
We are having the same trouble with the solenoid module. We are using an 8 port CRio, so we have declared our solenoid as
Solenoid s1 = new Solenoid(1,1);
Solenoid s2 = new Solenoid(1,2);
We have the solenoid module plugged into port 8 of the Crio and wired for 24V. We get a power light on the solenoid breakout, but when we upload the Java code, we get the error Solenoid Module 1 is not present (4 times on one deploy). Should any of the 8 leds be on when we boot up to signal that the module has power?
Thanks for the help.
Unread 19-02-2013, 18:13
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
On an 8-slot, Solenoid Modules go in cRIO chassis slots 3 & 7
