Go to Post If it gets people talking about not only robots but science and technology, it's all good. - Koko Ed [more]
Unread 08-02-2012, 11:27
TehNovak's Avatar
TehNovak TehNovak is offline
Skaian Programmer
AKA: Doc Scratch
FRC #4053 (Robot Ascension)
Rookie Year: 2012
TehNovak is an unknown quantity at this point
Exclamation Team 4053 is not even close to done! DX
We have run into almost every problem imaginable, from faulty programs to errors to mechanical problems and so forth. We need a lot of help right now. all we are trying to do at the moment is to get the two motors we have to run in response to input from two joysticks. but its not working. at all. If theres anything anyone can do to help, Im happy to give details, provide videos, pictures, etc. anything we need to do to get it running. thank you very much.
[I am an excellent host.]
Unread 08-02-2012, 11:29
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: Team 4053 is not even close to done! DX
Got a location? I'm sure any local team would send a few people over to get you up and running.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 08-02-2012, 11:34
TehNovak's Avatar
Skaian Programmer
AKA: Doc Scratch
Rookie Year: 2012
We are in Louisiana. Gonzales, Louisiana, to be exact. East Ascension High School is our school.
Unread 08-02-2012, 11:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Cool. Nowhere near us, but hopefully a local team will find this thread! You might also want to check TIMS for contact info from local teams.
A few preliminary questions:
Digital sidecar ribbon cable okay?
Do the Jags'/Victors' lights change color when joystick input is applied, or do they stay orange/blinking?
Flashed cRIO with the latest firmware?
Easy things to check for:
PWM cable orientation, black to black, red to red...
PWM cables are actually plugged in. They can get misaligned and seem plugged in, but actually are not.
Crimp connectors are actually crimped and tight.
Wire was stripped prior to being crimped.
Wire installed in the power distribution board is stripped.
Breakers are installed.
Good luck!
Unread 08-02-2012, 11:44
TehNovak's Avatar
Skaian Programmer
AKA: Doc Scratch
Rookie Year: 2012
The one thing I do know for sure, the Jaguars stay just blinking orange. the ribbon is okay.
Unread 08-02-2012, 11:54
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
To play devils advocate, did you check every pin on the ribbon cable for continuity? It's very easy to install the terminals incorrectly.
Unread 08-02-2012, 11:56
TehNovak's Avatar
Skaian Programmer
AKA: Doc Scratch
Rookie Year: 2012
I have not, no. even so, is the jaguars not changing colors incorrect?
Unread 08-02-2012, 12:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'd double-check that, and any component that is potentially questionable. It pays to be skeptical in this regard.
Have you verified cRIO communication? I.e. flashed it and downloaded code?
It might also help to post up your robot code for other programmers to look at.
Unread 08-02-2012, 12:15
nocapitals's Avatar
nocapitals nocapitals is offline
FRC #3539 (The Byting Bulldogs)
Rookie Year: 2011
nocapitals is an unknown quantity at this point
What programming language are you using?
I had this dream last night! I joined a robotics team and...oh god...
Unread 08-02-2012, 12:36
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Some of the ribbon cables were sent backwards too. We had that problem at first.(If your sure your code is correct).
Unread 08-02-2012, 13:06
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
If you're sure about the hardware, than what you should look at is whether the jaguar does what it's supposed to do. When you throw the joystick into full forward, the jag should rapidly blink green. Or at least turn green. If not than there's a wiring issue.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 08-02-2012, 11:49
andrewthecow's Avatar
andrewthecow andrewthecow is offline
FRC #3753
andrewthecow is an unknown quantity at this point
Hey, I'm a student from team 3753, Parkview Baptist in Baton Rouge. We'd be glad to help y'all as much as we can. Send me a private message with contact information and I'll see we can do.
