Go to Post Deadlines are part of everyday life. - Steve W [more]
Unread 08-02-2012, 16:02
gizzerd91 gizzerd91 is offline
FRC #2498
gizzerd91 is an unknown quantity at this point
Laptop Vision and Converting between WPIBinaryImage and BinaryImage
If anyone is making an effort to do vision on the laptop, let me make your life a little bit easier. Here is the (almost) working code for a vision processing widget in SmartDashboard that I found and have been tinkering with. Right now it's kind of a frankenstein of Greg's code and the stock vision code.
Code:
package edu.wpi.first.smartdashboard.extension.vision;
import edu.wpi.first.smartdashboard.camera.WPICameraExtension;
import edu.wpi.first.smartdashboard.robot.Robot;
import edu.wpi.first.wpijavacv.WPIBinaryImage;
import edu.wpi.first.wpijavacv.WPIColor;
import edu.wpi.first.wpijavacv.WPIColorImage;
import edu.wpi.first.wpijavacv.WPIContour;
import edu.wpi.first.wpijavacv.WPIImage;
import edu.wpi.first.wpijavacv.WPIPoint;
import edu.wpi.first.wpijavacv.WPIPolygon;
import edu.wpi.first.wpilibj.image.BinaryImage;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.CriteriaCollection;
import edu.wpi.first.wpilibj.image.NIVision.MeasurementType;
import edu.wpi.first.wpilibj.image.NIVisionException;
import edu.wpi.first.wpilibj.image.ParticleAnalysisReport;
import edu.wpi.first.wpilibj.image.RGBImage;
import edu.wpi.first.wpilibj.networking.NetworkTable;
import java.util.ArrayList;
import java.util.logging.Level;
import java.util.logging.Logger;
 * @author Greg Granito
public class LaptopVisionRobot extends WPICameraExtension {
    public static final String NAME = "Robot Camera Square Tracker";
    NetworkTable table = NetworkTable.getTable("camera");
    WPIColor targetColor = new WPIColor(255, 0, 0);
    criteriaCollection cc;
    @Override
    public void init() {
        cc = new CriteriaCollection();      // create the criteria for the particle filter
        cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_WIDTH, 30, 400, false);
        cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_HEIGHT, 40, 400, false);
    @Override
    public WPIImage processImage(WPIColorImage rawImage) {
        WPIBinaryImage blueBin = rawImage.getBlueChannel().getThresholdInverted(100);
        WPIBinaryImage greenBin = rawImage.getGreenChannel().getThresholdInverted(100);
        WPIBinaryImage redBin = rawImage.getRedChannel().getThresholdInverted(100);
        WPIBinaryImage finalBin = blueBin.getAnd(redBin).getAnd(greenBin);
        try {
            finalBin.erode(2);
            finalBin.dilate(6);
            BinaryImage thresholdImage = finalBin;
            BinaryImage bigObjectsImage = thresholdImage.removeSmallObjects(false, 2);  // remove small artifacts
            BinaryImage convexHullImage = bigObjectsImage.convexHull(false);          // fill in occluded rectangles
            BinaryImage filteredImage = convexHullImage.particleFilter(cc);           // find filled in rectangles
            WPIContour[] contours = finalBin.findContours();
            ArrayList<WPIPolygon> polygons = new ArrayList<WPIPolygon>();
            for(WPIContour c : contours){
                double ratio = ((double)c.getHeight()) / ((double)c.getWidth());
                if(ratio < 1.5 && ratio> 0.75){
                    polygons.add(c.approxPolygon(45));
            ArrayList<WPIPolygon> possiblePolygons = new ArrayList<WPIPolygon>();
            for(WPIPolygon p : polygons){
                if(p.isConvex() && p.getNumVertices() == 4){
                    possiblePolygons.add(p);
                }else{
                    rawImage.drawPolygon(p, WPIColor.CYAN, 5);
            WPIPolygon square = null;
            int squareArea = 0;
            for(WPIPolygon p : possiblePolygons){
                rawImage.drawPolygon(p, WPIColor.GREEN, 5);
                for(WPIPolygon q : possiblePolygons){
                    if(p == q) continue;
                   int pCenterX = (p.getX() + (p.getWidth()/2));
                   int qCenterX = q.getX() + (q.getWidth()/2);
                   int pCenterY = (p.getY() + (p.getHeight()/2));
                   int qCenterY = q.getY() + (q.getHeight()/2);
                   rawImage.drawPoint(new WPIPoint(pCenterX, pCenterY), targetColor, 5);
                   rawImage.drawPoint(new WPIPoint(qCenterX, qCenterY), targetColor, 5);
                    if(Math.abs(pCenterX - qCenterX) < 20 &&
                        Math.abs(pCenterY - qCenterY) < 20){
                        int pArea = Math.abs(p.getArea());
                        int qArea = Math.abs(q.getArea());
                        if(pArea > qArea){
                            square = p;
                            squareArea = pArea;
                        }else{
                            square = q;
                            squareArea = qArea;
                        break;
            if(square != null){
                double x = square.getX() + (square.getWidth()/2);
                x = (2 * (x/rawImage.getWidth())) - 1;
                double area = ((double)squareArea) /  ((double)(rawImage.getWidth() * rawImage.getHeight()));
                synchronized(table) {
                table.beginTransaction();
                    table.putBoolean("found", true);
                    table.putDouble("x", x);
                    table.putDouble("area", area);
                table.endTransaction();
                Robot.getTable().putBoolean("found", true);
                Robot.getTable().putDouble("X", x);
                Robot.getTable().putDouble("Area", area);
                rawImage.drawPolygon(square, targetColor, 7);
            }else{
                table.putBoolean("found", false);
                Robot.getTable().putBoolean("found", false);
        } catch (NIVisionException ex) {
            Logger.getLogger(LaptopVisionRobot.class.getName()).log(Level.SEVERE, null, ex);
        return finalBin;
The major trouble I'm having, and why you'll find this doesn't compile, is the
Code:
In order to do higher order image processing, I need to convert from WPIBinaryImage to BinaryImage, but there doesn't seem to be a way to do this. My only alternative at this point is to physically save a bitmap to the harddrive, then read it out, but that is sooooo slow. Anybody have any ideas?
