Go to Post ...he's acting like a programmer whose code is compiling...:yikes: - EricH [more]
Unread 08-02-2012, 16:15
Silver218's Avatar
Silver218 Silver218 is offline
FRC #1827 (Robo-Jackets)
Rookie Year: 2010
Silver218 is an unknown quantity at this point
cRio Communication Errors
We have had success with reading the cRio on one our mentors laptop but on our personal minicomputer and on another personal laptop, (both running windows 7 & have current 2012 LabVIEW, and FRC Driver Station), we have not been able to connect to the cRio.
Everything is set up properly, meaning we have changed our network settings to match the driver station, we are using a crossover cable to manually tether, & all current updates have been installed on all computers. However, we keep on getting a reading of "No Communication" and "No Robot Code" on the Driver Station window.
Our code is set to run as startup, which will show up on our mentors laptop but not on the other two computers.
Please feel free to offer any troubleshooting options or suggestions
Unread 08-02-2012, 16:20
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Re: cRio Communication Errors
Try making the IPv4 address different than what it is. If it's 10.xx.yy.1, try 10.xx.yy.3 or something to that measure. We've had this issue and changing the IP address worked for us.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 08-02-2012, 16:24
Silver218's Avatar
Rookie Year: 2010
@nitneylion452 Trying your suggestion now. Thanks!
Unread 08-02-2012, 19:02
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
The standard ip addresses are:
cRIO: 10.te.am.2
bridge: 10.te.am.1
router (if you are using one in addition to the bridge): 10.te.am.4
driver station computer: 10.te.am.5 or 6, but larger numbers work as well
camera: 10.te.am.11
Can you ping the robot at 10.te.am.1? If you can, your networking is probably set up properly (it could be a problem with your driver station configuration).
