Go to Post We are behind you 100% (more if needed)! - Clem1640 [more]
Unread 08-02-2012, 17:06
SamB SamB is offline
SamB is an unknown quantity at this point
Mechanism to lift chassis
We are thinking of having a regular chassis with 6" wheels. We want to have some form of a mechanism, which would drop down, and lift the entire chassis up, and help it go over the bump.
We thought of ideas such as pneumatics, as well as a rack and pinion.
Any suggestions as to what would be the most effective way to do this?
Thank you
Unread 08-02-2012, 17:10
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: Mechanism to lift chassis
We just used drop brackets and another set of 6 inch wheels...so the first set hit the bump one inch below the half line, and then lift up the next set. We thought about doing this with some sort of lever mechanism using pneumatics, but we were concerned it would take too long for us to learn how to make it right. We plan on figuring it out in the off season. Here is a pic of what we came up with:
Unread 08-02-2012, 17:14
eedoga's Avatar
FRC #2980
Here is another idea from team 488.
http://www.youtube.com/watch?feature...&v=nQgri9TRI78
Unread 08-02-2012, 19:22
n1ckd2012's Avatar
n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
Rookie Year: 2010
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
We are going with wheel drops kinda like the above picture. But I would try switching your current wheels for plaction roughtop wheels. We have found those to interact nicely with the metal bump.
http://www.andymark.com/product-p/am-0437.htm
Check out our daily build log here
http://2012.discobots.org/node/31
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
