Go to Post Back in the old days, we didn't have clues, and we liked it! - Joe Ross [more]
Unread 08-02-2012, 17:24
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
Rookie Year: 2012
agartner01 is an unknown quantity at this point
How to make the Gyro work
Well after not being able to get the accelerometer to work, I'm going to try the gyro. But of course its not that easy. I just get a bunch of numbers that increment up. (Ex:2.97922e+087) Code and Pictures:
Code:
Gyro *gyro;
gyro = new Gyro (1);
gyro->Reset();
std::cout<<gyro->GetAngle()<<endl;
Unread 08-02-2012, 17:30
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: How to make the Gyro work
Wait, am I looking at it correctly? It seems you are connecting to channel one of the analog bumper, but the analog bumper is inserted into the solenoid module. It also looks like your "solenoid bumper" is inserted into your analog module. In other words, you have swapped your analog and solenoid bumpers.
Unread 08-02-2012, 17:40
FRC #4174
Rookie Year: 2012
Yep, came here to post that very thing... I got it working now... We totally know what we're doing...
Unread 08-02-2012, 22:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Where did you get that cable you're using to connect the sensor to the Analog input pins? The wiring scheme is decidedly nonstandard, with power on the black wire and common on the red. That's likely to cause some confusion if you ever need to troubleshoot it.
Unread 08-02-2012, 22:21
FRC #4174
Rookie Year: 2012
I got if from the KOP. It was the only f-f 3 pin cable.
