Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 08-02-2012, 19:18
Maxog Maxog is offline
FRC #3471
Maxog is an unknown quantity at this point
Rightsight Photoswitch Photoelectric Sensors
Hello, Matthew and Brandon here from team 3471. We are a 2nd year team and we would like to use the Rightsight Photoswitch Photoelectric Sensors from last year's KOP. However, due to us being a 2nd year team, NONE of us know how to program these. We have searched everywhere for a guide, tutorial, or even basic code for these senors. They do not have a product ID either, making even the example finder useless. We understand this may be alot to ask for, but could someone please explain (or post a link to) how in the world do we set these up for basic readings/detections (we can do the programing from there). We wish to use them to recognize how many balls we have in queue inside of our turret. They were in last years autonomous VI, however this has helped us to no avail. It should also be noted that our chief mentor on programming refuses to touch the programming for these due to a 12 hour session he had programming these a few years ago. Can anyone just set up a basic framework so we can detect whether or not we have a ball in queue for three of these sensors?
Unread 08-02-2012, 21:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Rightsight Photoswitch Photoelectric Sensors
Check out the Part Data Sheets from last year's KOP website. http://www.usfirst.org/roboticsprogr...c-kit-of-parts
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 08-02-2012, 23:22
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Wiring:
Brown goes to power, a red Wago terminal on the Power Distribution Board protected by a 20 Amp fuse.
Blue goes to power return, the associated black Wago terminal on the PDB.
Black goes to the signal pin of a DIO port on the Digital Sidecar. You can use white instead; white gets pulled low when the sensor detects an object, and black gets pulled low when the sensor does not detect an object.
Programming:
It's just a digital input. Open the DIO pin in Begin; read it in Teleop; close it in Finish.
Unread 17-02-2012, 18:36
FRC #3471
How do you program the digital input in begin and teleop vi.'s?
Unread 12-07-2012, 02:22
peterjhon peterjhon is offline
FRC #0009
peterjhon is an unknown quantity at this point
Photo sensor switches are best for advertisement. These switches provide 24 hours service. Many advertising companies are using photo sensor switches because it is one time worthy investment. So companies are switching back to photo sensor switches rather than using traditional sign board for advertising.
_________________________________________
PHOTO SENSOR SWITCH
