Go to Post No, no, no, it's a fire game. The pool is there in case of accidents. - artdutra04 [more]
Unread 08-02-2012, 19:28
Lord_Arion Lord_Arion is offline
FRC #3673
Lord_Arion is an unknown quantity at this point
Bumpers
Our team is looking for ideas on how to attach our bumpers to the robot and were wondering if any other teams had some good ideas that allow for quick and easy placement and removal.
Thanks in advance,
Lord Arion
Unread 08-02-2012, 20:39
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Bumpers
Quite a bit depends upon the structure of your frame. are you using the C-channel from the kit bot?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 08-02-2012, 21:01
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Re: Bumpers
We are trying a new method this year of using carriage bolts and wing nuts through aluminum angle mounted to the chassis. Not done yet, but it looks like it is going to work well! Good luck!
2011 Record (11-3-0)
Unread 08-02-2012, 21:48
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Bumpers
Just bear in mind that they need to be able to be taken off and on quickly. We had that method last year (If I understand you correctly) and it was painful physically and figuratively
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 08-02-2012, 22:10
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: Bumpers
In the past, we have had vertical pieces of 80/20 on the corners of the robot. We would put screws into the back of the plywood, leaving the heads exposed in order to slide down the raceway of the extrusion stock. It is admittedly a pain to get right at first, but they slide off so easily that I definitely feel that the effort up front is worth it in the end.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 08-02-2012, 22:35
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Re: Bumpers
We have used quick release pins on our bumpers for the last two years and really like them. A quick Google Image search will show you what I mean. We put an aluminum angle bracket, permanently attached to the bumper, on the top and bottom of a frame rail and drop the pin straight through (2 per bumper). The brackets take up all the up/down forces, while the shear strength of the pin holds the bumpers on. So the bumper mount is invincible, but they go on and off in a matter of seconds.
And I can't quite figure out how something can be figuratively painful...
Unread 08-02-2012, 23:09
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Bumpers
We fabricated a piece of channel that slides over the simple chassis channel. drilled a hole that matches the hole in the simple chassis & secured them with quick release pins. You can get the pins at Grainger, McMaster Carr, MSC, ETC
Unread 10-02-2012, 17:08
Dlowell Dlowell is offline
FRC #4283
Dlowell is an unknown quantity at this point
Re: Bumpers
What kind of quick release did you use was it one of the "D" ring quick release or was it a butterfly pin holding it in place?
Unread 11-02-2012, 11:32
on walkabout
Re: Bumpers
They look pretty much exactly like this.
