Go to Post and thats my tip of the day. - Tytus Gerrish [more]
Unread 09-02-2012, 08:46
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
Error
Hi, I have the following error displayed on the driver station when teleop is enabled:
Code:
ERROR: A timeout has been exceeded: RobotDrive...Output not updated often enough. ...in Check() in c:/Windriver/workspace/WPILib/MotorSafetyHelper.cpp at line 123
I am using the SimpleRobot example and I also used the following code as well and received the same result:
Code:
#include "WPILib.h"
class Robot : public IterativeRobot
	RobotDrive myRobot;
  	Jaguar ballpicker;
  	Joystick leftStick; // left joystick in USB 1 of the DS
  	Joystick rightStick; // and right JS is in USB 2 of the DS
  	Solenoid sol1;
  	Solenoid sol2;
  	Compressor compress;
  public:
  Robot():
    		myRobot(1,2), // Drive Motors
    		ballpicker(3), // Motor That Picks Up Balls
    		leftStick(1),
    		rightStick(2),
    		sol1(2,1), // MIGHT HAVE TO CHANGE FIRST COORDINATE BECUASE MODULES-
    		sol2(2,2), // HAVE CHANGED THIS YEAR!!!
    		compress(1,1)
   // Any Constructor Code Here...
  		void TeleopInit()
       GetWatchdog().SetEnabled(true);
       compress.Start();
  		void TeleopPeriodic()
    	GetWatchdog().Feed();
    	myRobot.ArcadeDrive(leftStick); // Arcade Style--> Left Stick
    	if (leftStick.GetRawButton(3))
    		ballpicker.Set(0.1); // --> If Button 3-->Input-->10% Power
    	else
    		ballpicker.Set(0.0); // --> If Button 3-->No Input-->No Power
		} // Left Stick Is For Driver/Ball Picker Up'er
    	if(rightStick.GetTrigger()) // Right Stick Is For Shooter
    		sol1.Set(true); // --> If Right Trigger-->Input-->Valve 1-->True
    		sol2.Set(false); // --> Valve 2-->False
    	else
    		sol1.Set(false); // --> If Right Trigger-->No Input-->Valve 1-->False
    		sol2.Set(true); // --> Valve 2-->True
    	Wait(0.005); // --> Allows Time for Motor Refresh/Update
START_ROBOT_CLASS(Robot);
I don't see any errors in my code and have had it checked by another individual as well.
Please help.
Thank You.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
Unread 10-02-2012, 00:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Error
Is the robot working as expected despite the displayed error?
Unread 10-02-2012, 10:33
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Error
We also have this problem. When we have it all the pwms associated with the RobotDrive are disabled. All others work.
We have used feeding the watchdog as a work around. The MotorSafety true/false has not been a solution. I still cannot directly use those pwms without allocation errors and it does not work in my autonomous section. What we don't know is why this year's version of Windriver/robot image cannot use last year's code on the robot.
Andy Brockway
Team 716, The Who'sCTEKS
