Go to Post ...isn't that part of the point? For high schoolers to do things they "could not have" by themselves? - AdamHeard [more]
Unread 09-02-2012, 12:22
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
Can we wire Jaguar to one of the small ports on the PDU?
Hello,
We have now realized we need to activate 9 motors on our robot, but the problem is there are only 8 "large" ports (the red and black ones) on the PDU.
Is it okay (according to the rules and in general) to wire a jaguar to the one of the small ports? what will be the results? will we notice some changes in the motor behavior?
Also, are we allowed to use Victors this year?
if so - how about connecting them to the small ports?
Thank you very much.
Unread 09-02-2012, 13:18
dudefise dudefise is offline
FRC #2637 (Panthers)
Rookie Year: 2011
dudefise is an unknown quantity at this point
Re: Can we wire Jaguar to one of the small ports on the PDU?
Yes, you can. The "big" ports are for 40-amp breakers and are for handling the largest motors, like CIMs, 775s, etc... The smaller ones will run the jaguar and the motor the same when unloaded, but can only handle a 20 or 30 amp load depending on what breaker you use. This could mean not being able to hold at full current, or the breaker tripping if you use too large of a motor or run it under a lot of load
If you are using smaller motors, like window motors, I would put those on the smaller circuit.
Victor 884's are allowed this year and will function as stated above if attached to a 20 or 30 amp circuit.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 09-02-2012, 13:20
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Originally Posted by NeatTeam View Post
Hello,
Both Jaguars and Victors (and Spikes) may be wired to the small ports on the PDB.
For Jaguars and Victors, the largest allowed circuit breaker in those small ports is 30 A (because that is the largest size of breaker provided that fits those slots). If you need 40 A, you must use a large port. For Spikes, it is 20 A.
See [R43] for full details.
Unread 09-02-2012, 15:05
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Neat,
The breakers are meant to protect the wiring from catastrophic failure. The breakers are sized according to the minimum wire they are used with. A speed controller wired with #18 wire can be fed from a 20 amp breaker. Likewise, a 20 amp breaker could also be used with #10 wire. It is the minimum wire size that must be satisfied.
I would recommend you use the smaller breakers for smaller motors. Smaller Banebots, window motors and some of the AndyMark motors would fit into this category. Save the 40 amp slots for the motors that will be doing the most work like the CIMs in your drivetrain.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-02-2012, 17:54
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
I don't think #10 will fit in the smaller terminals. I think I read somewhere that they're designed to fit #12 - #22 wire.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 11-02-2012, 05:44
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
Team Role: Coach
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
A #10 gauge wire will fit into the 20/30 amp slots on the PDB, it just takes a little time to get them in. As per the original question you can use a jag or victor 884 with the 20/30 amp power ports.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 11-02-2012, 08:47
Unsung FIRST Hero
Rookie Year: 1996
Max,
The #10 reference is meant to demonstrate the rules not the application.
Al
WB9UVJ
www.wildstang.org
