Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Unread 09-02-2012, 22:33
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Encoders and gyro - no idea
Programming in java, absolutely no idea whats wrong but both the gyro and the encoders attached to the motors give no output.
the encoders are attached to channels 1,2,3,4 (I didnt wire, and dont know how to) in slot 2. The gyro is in slot 1 on channel 1. We have inputed these values into our code but still no real input. Gyro gives a float point that means nothing (Still a number but not useful) and the encoders simply give us 0. Thought I'd ask you good people for some advice since we have no idea. (No experience with FRC, I'm good with Java)
Thanks in advance
Unread 10-02-2012, 00:44
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
Rookie Year: 2010
jesusrambo is an unknown quantity at this point
Re: Encoders and gyro - no idea
Mind sharing your code?
Unread 10-02-2012, 18:38
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Make sure you didn't declare the encoders in slot 2. The first instance of every module is coded as 1, even though the first sidecar is in slot 2. Just remove the slot declaration from your code and leave the channel declaration.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 12-02-2012, 08:56
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
Rookie Year: 2011
java4first is an unknown quantity at this point
Not sure it's your problem (assuming the wiring for the two channels is correct) - but my first mistake was that the Encoders require a reset() - probably optional - and start() method invocation before you start getting data out of them.
Not sure about the gyro - that worked as advertised.
