Go to Post But, as a mentor I should caution you that FIRST is not about you its about the students. - SomeoneKnows [more]
Unread 09-02-2012, 22:44
a240 a240 is offline
FRC #2713
a240 is on a distinguished road
Problems using CAN with PID
Hello,
I've been trying to use the CANJaguar class with PID control, but due to a lack of examples and documentation it has been a lot of guess and check work. I have successfully created a CANJaguar object and correctly configured it to the point where I could get encoder feed back. However I have run into a bit of trouble trying to use PID Control with the robot.
Here is some sample test code I created for a CANJaguar based driveTrain: http://code.google.com/p/iraiders-fr...riveTrain.java
My problem is that even after setting a setpoint value using setX(x), the driveTrain wheel fail to move. Testing shows that the method getX() returns a value of zero. What's wrong? If anyone knows anything about the topic any information would be very helpful.
