Go to Post Without compromise, engineering would be boring. - Mike Betts [more]
Unread 10-02-2012, 12:22
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Lowering the speed of a motor threw a victor jaguar
How do we lower the speed for a motor using a victor jaguar. We are using this motor for a robotic arm. We are using LabView.
Thanks for your time
Unread 10-02-2012, 12:41
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Lowering the speed of a motor threw a victor jaguar
What do you mean you have a Victor Jaguar?
You only need one or the other, you don't use both together.
Unread 10-02-2012, 13:00
FRC #4166
Just a victor.
Unread 10-02-2012, 13:06
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Then (I don't know LabView) but give the Victor a different value. It should be something like -1 to 1, with -1 being full reverse, 1 being full forward.
Something like .5 would be half speed.
Unread 10-02-2012, 14:36
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Depends on your control method, but you can multiply a Joystick axis value by a percentage (e.g., .9 or .75) before it goes into the Motor Set Output.
Then max power will be limited (e.g., to 90% or 75%).
Name:	Cut Motor Power.png
Unread 10-02-2012, 15:09
FRC #4166
Thanks for the advise. We will try it.
John
Unread 10-02-2012, 15:36
FRC #4166
The two small wires on the victor I am assuming are to power the fan. Where would you recommend wring those. We were thinking they should be wired on the power side of the victor, but not sure.
thanks
jalmos
Unread 10-02-2012, 15:43
Just Itinerant
You've got it. They wire into the power side of the Victor.
They should be on all the time keeping things cool whenever the robot is powered.
