Go to Post *gasp* robot? what robot? we were suppose to build a robot? - LightWaves1636 [more]
Unread 10-02-2012, 16:11
sretter's Avatar
sretter sretter is offline
AKA: Shaked
FRC #2231 (OnyxTronix)
Team Role: Leadership
Rookie Year: 2010
sretter is on a distinguished road
Legal Bumpers?
Hi everyone,
After checking the bumper rules and everything we wanted to make sure that our bumpers are 100% legal.
The bumpers and frame are similar to this picture(forgive me for my poor graphic skills):
http://up353.siz.co.il/up2/mkzvllzthdmg.png
Black line is frame and red line is bumper and the length and width are shorter than the maximum...
Thanks!
Unread 10-02-2012, 16:17
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Re: Legal Bumpers?
I'm not sure. I need some clarification before I can tell you anything.
Are the bumpers 8" from the corner of the frame, or 8" total on the front and back? They must be 8" long from the corner of the frame inward to be legal, i.e. you must have ~11.25" of bumper on the front on either side.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 10-02-2012, 16:27
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: Legal Bumpers?
Unless, of course, they have it set up so that their side bumpers cover the additional ~3 inches on both the front and back.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 10-02-2012, 16:34
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Legal Bumpers?
No, you bumpers must cover 8" or more on each side of every exterior vertex - that's measured from the vertex of the frame perimeter, so you have to have 8" of frame covered. Your side bumpers cannot count towards any of that 8".
Unread 10-02-2012, 16:36
AKA: Joe Lee
Rookie Year: 2010
Re: Legal Bumpers?
My point remains valid. There must be 8" of bumper attached from the corner to another point inward of the frame.
[R27]
Robots are required to use Bumpers to protect all exterior vertices of the Frame Perimeter. For adequate protection, at least 8 in. of Bumper must be placed on each side of each exterior vertex
Joe
Unread 10-02-2012, 17:07
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Legal Bumpers?
It appears from your drawing that the ends of the "U" of your frame are 8 inches wide. If so, you will be OK.
To put it simply, at every exterior corner of your robot, the frame must be protected by the Bumper for 8" on both sides of the corner.
Is there a reason that you don't have a bumper all the way across the back of your robot? It's free weight, and it will help protect you. But if there's some strategic reason for leaving the gap, you are allowed to do so as long as you comply with the 8" rule at every corner.
(since 2004)
Unread 10-02-2012, 18:59
sretter's Avatar
AKA: Shaked
Rookie Year: 2010
Re: Legal Bumpers?
Thanks!(and yes it's 8 inches from the corner)
and about the gap in the back we want to keep open a possibility to pick up ball from there.
Unread 10-02-2012, 21:28
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Team Role: Mechanical
Rookie Year: 1997
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
Re: Legal Bumpers?
Just to be clear it is NOT measured from the end of the pool noodle .I read a e-mail today from a top robot inspector in FIRST that clearly stated bumpers are measure by the wood.
"The GDC has responded in the Q&A on this question but it is consistent with the rules as written. The bumper length is that which is defined by the backing board. So the 3/4 plywood has to be 8" min on either side of any exterior vertices. The soft parts that make up a corner are part of the bumper system but are not backed up by frame structure. With wrap around bumpers, the 3/4" plywood must satisfy the rule. as shown in the rules. "
I hope this helps. We are currently making the needed changes.
Team 107 Holland Christian / Metal Flow
2005 Midwest semi finalist
2005 Johnson & Johnson sportsmanship (midwest)
2005 West michigan Champs with 93 and 66
2005 Johnson & Johnson sportsmanship (west michigan)
2005 web site award
Unread 11-02-2012, 12:30
tcjinaz tcjinaz is offline
Tim
FRC #3853
Rookie Year: 2011
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Re: Legal Bumpers?
I would buy that if it were a public communication. The Q&A has not been answered yet.
Software Mentor
3853 Pridetronics[
Unread 10-02-2012, 22:13
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Legal Bumpers?
Also pay attention to how you fasten those C-shaped bumpers to the frame. There are rules on that, too.
Unread 11-02-2012, 07:40
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
Rookie Year: 2011
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Re: Legal Bumpers?
DonRotolo,
Could you refer me to the attachment rules that apply to attachment, just so that I don't do something stupid.
Unread 11-02-2012, 13:13
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Legal Bumpers?
Originally Posted by wilhitern1 View Post
DonRotolo,
The attachment stuff has been in the bumper rules all build season.
Particularly read [R28-E] (and the [R28] blue box), [R32], and [R33].
Tim, I'd like to point you to the following Q&A responses:
Game - The Robot » Bumper Rules » R27
Q. Does the 8" of bumpers required on each side of vertex include the 3" of the bumper meeting it from the connected side? Or does the bumper need to be 8" of plywood with noodle. In Figure 4-1 it appears that the upper left horizontal bumper is 8", and the vertical is 6" with no plywood on the end.
A. Per Rule [R27], the Bumper must be at least 8 in. Per Rule [R28], the Bumper must be backed by plywood. Thus, the plywood must be 8 in. The figures in Section 4.1.6 are for illustrative purposes only and are not drawn to scale.
Q. Figure 4-1 shows short segments of bumper on each side of an opening. 4.1.6 says that the minimum length of bumper is 8". But does the 8" include the part of of the bumper that overlaps with a bumper on the adjacent side, or only the part that is backed up by the chassis? A measurement added to Figure 4-1 would be really helpful.
A. The 8 in. specified in Rule [R27] does not include overlapping sections of bumper material found at an exterior vertex.
(emphasis mine)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 11-02-2012, 14:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Legal Bumpers?
Thanks Eric.
Unread 11-02-2012, 17:13
Tim
FRC #3853
Rookie Year: 2011
Re: Legal Bumpers?
Tim, I'd like to point you to the following Q&A responsesemphasis mine)
Thank You. I lost it (two in a row) in the 3 pages of bumper rule questions.
Wish the diagrams in the rules had dimensions etc on them.
Software Mentor
3853 Pridetronics[
