Go to Post Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. - RoboChair [more]
Unread 10-02-2012, 18:40
SMHS SMHS is offline
Jay Maine
AKA: Dan Lemieux
None #3930
Team Role: Coach
Rookie Year: 2011
SMHS is an unknown quantity at this point
Cim-Sim vs a Bane Bots 755 cim sim
We have a Bane Bot CIM-U-LATOR Gearbox, 1 RS-775 size motor for our shooter. But I am look at the Cim-Sim from Andy Mark which is going to work better on a ball shooter. I can seem to find any information to compare the two. Rookie team trying to figure out motors.
Unread 10-02-2012, 19:10
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Cim-Sim vs a Bane Bots 755 cim sim
What is it that you're trying to find out?
The pertinent information is listed on the Andy Mark Website. For instance, a 775 won't fit on a Cim-Sim without modification of the gearbox.
Unread 10-02-2012, 19:20
Jay Maine
AKA: Dan Lemieux
None #3930
Team Role: Coach
Rookie Year: 2011
Which is going to give me the best performance as a drive motor system for my shooter system? I have the Bane bots 755 cim-u-lator and was thinking of purchase the cim-sim. I just looking for information on the best over all performance.
Unread 10-02-2012, 21:15
Tom Line's Avatar
Rookie Year: 1999
Have you decided a distance you'd like to shoot, decided on a wheel or roller size, decided on a gear ratio that will get the wheel size you've chosen to output speed to get the distance you want, then determined which motors are required? Do you have the machining knowledge to modify a Cim-sim to work with 775 motors? Do 775 motors through a Cim-sim get you the torque and speed you want?
Unread 10-02-2012, 22:30
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
In order to answer this question, we need to know a few things.
1) what are the specs of your shoooter (wheel size, # of wheels, exit velocity expected, etc)
2) What is your machining capability (775s don't mate with Cim-Cims)
3) what performance are you expecting
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 10-02-2012, 23:24
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
If you want the results of a CIM motor for your shooter I recommend using a Banebot P60 with your RS-775. 4:1 reduction should give you the same freespeed as a CIM moto
Last edited by O'Sancheski : 10-02-2012 at 23:25. Reason: I need to learn how to spell
