Go to Post I am surprised at the relative conservative capability you described on our 2006 machine. As for the 2007 machine, in anticipation of an aquatic game, we have completed a robot that "walks on water" and are well along with one that can "part the sea". - Bill Beatty [more]
Unread 11-02-2012, 09:36
Quellek2 Quellek2 is offline
FRC #4121
Quellek2 is an unknown quantity at this point
Exclamation Axis Camera issues... Please help!
We are a rookie team, so we really don't know what's going on
We got the camera to display an image on the dashboard, however when we try to load in it the vision assistant, we always get a "check IP and cables" error and cant load an image.
Even with that, we have no idea how to get the rectangle tracking working...
Unread 11-02-2012, 10:05
haljarrett haljarrett is offline
FRC #4189 (Jackson-Barrow Robotics)
Rookie Year: 2012
haljarrett is an unknown quantity at this point
Re: Axis Camera issues... Please help!
Have you followed the instructions for setting up the camera using the "setup Axis Camera" tool included with the kop?
Unread 11-02-2012, 10:36
FRC #4121
Ok, we found a really roundabout way to get an image into vision assistant, however we still don't know what to do with that.
Unread 11-02-2012, 18:08
rivasm rivasm is offline
FRC #2556 (RadioActive Roaches)
Rookie Year: 2010
rivasm is an unknown quantity at this point
I'm not sure if this is still relevant, but there is a tutorial that I recently learned about a tutorial with the Rectangle Target Processing vi in Help>>Find examples. We're still having troubles implementing it, but it's a start.
Unread 11-02-2012, 18:12
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Rookie Year: 2011
Keyreaper is an unknown quantity at this point
Our team of programmers, me included as the leader of that team, was completely confused when looking at that code... It made no sense to me. I'd sure like it to work though... Like copy pasta, "Hey look it works!".
Unread 12-02-2012, 10:56
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Go through the LabVIEW Tutorial 8—Integrating Vision into Robot Code and you should have what you want.
Unread 12-02-2012, 12:08
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Rookie Year: 2011
Woah... I haven't looked at these . Best I get to seeing all of them! Thanks Alan.
Unread 12-02-2012, 21:34
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
Rookie Year: 2010
MAldridge will become famous soon enoughMAldridge will become famous soon enough
Merry Christmas! (see attachments)
just drop rectangular processing into the vision OUTSIDE OF THE LOOP. Then remove the loop and connect the devRef on the left. The targets terminal on the right gives coordinates and distance. This is just the example butchered to where it can be dropped in to look for color.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
