Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
Unread 11-02-2012, 12:35
mike1010100 mike1010100 is offline
FRC #1307 (RoboSaints)
mike1010100 is an unknown quantity at this point
Double Solenoid trouble
I am having trouble with my current solenoid code, when i press button one on joystick three it is supposed to activate, but it currently wont, also checked the voltage output with a meter and it wasn't changing from 12 volts.
any idea what the issue with the code is?
Unread 11-02-2012, 12:45
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
Re: Double Solenoid trouble
Do you have the pneumatics breakout wired and supplied with 12v? Do you see an LED lit on it?
http://www.usfirst.org/sites/default...20Breakout.pdf
When you activate your joystick button, does one of the lights on the NI 9472 change state?
If not, I'd look for errors on your dashboard, especially anything about an unknown device ref.
I might also try setting your solenoid on with a true constant, verify that works as expected, if it doesn't, you've got something wrong with the solenoid code, or the hardware of the pneumatics pieces.
You can always place a breakpoint and probe in the teleop code, and see what's what, are there any errors on the error outs, do you see the joystick button changing states as expected.
Unread 16-02-2012, 10:13
jwatson12 jwatson12 is offline
Mr. Watson
FRC #1025 (Impi Warriors)
jwatson12 is an unknown quantity at this point
If you are using a double selenoid in begin.vi, try using two singles instead. Then call them out individualy in teleop.vi.
Unread 18-02-2012, 02:37
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Is it a 24v solenoid? KOP had/has those. Andymark sells a 12v version. Mixing them without realizing it is vexatious.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
