Go to Post If you don't like physical play build a stronger robot. - Koko Ed [more]
Unread 11-02-2012, 14:11
jaysun jaysun is offline
Rookie Year: 2000
jaysun is an unknown quantity at this point
Axis camera video stream not showing in dashboard
As the title says, our axis camera video stream is not showing up in the dashboard. However, it does show up in the vision processing VI. We're running the camera out of the second ethernet port of the cRIO (instead of the d-link router). I attached a picture of the relevant dashboard code.
Any ideas what could be wrong?
ID:	11852  Click image for larger version
Unread 11-02-2012, 14:46
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Axis camera video stream not showing in dashboard
NI recently released a tutorial on how to use the camera in port 2 of the cRIO this year. It requires changes to both the dashboard and the robot project.
Unfortunately, the NI website is down right now.
Why do you want to use the camera on port 2 of the cRIO? You should get better performance with it connected to the dlink, and I don't know of any downsides.
